Fully built Benson Motor plus all my turbo stuff for Cheap!!!!!!!<---
Old Sep 9, 2009 | 12:23 PM
Rawgie's Avatar
Default Fully built Benson Motor plus all my turbo stuff for Cheap!!!!!!!<---
Ok this my last attempt to get rid of all my stuff
The motor runs strong and hard.
comp. test and leak down test was done before pulling the setup out.
I want $OLD!!!! for everything! This is a package deal
GSR Benson block 9:0:1 comp. 81mm bore (assembled, balanced and blueprinted at bensons)
CP pistons
ACL bearings
Manley Rods
2000 JDM type R head
jun valve springs
Golden Eagle fuel rail w/ RC 750 injectors
NGK plug wires
MSD distributor cap
ITS GT35R turbo .63 a/r
PWR back door intercooler w/ ER piping
HKS SSQ blow off valve
HKS GTII 60mm wastegate w/ box and accessories
ER 3" downpipe with flexpipe and cat.
ER dumptube
Full Race Ram Horn Manifold
Exedy twin disc clutch
97 GSR tranny w/ quafe LSD
S/X Fuel Pressure Regulator with fittings and Lines
Custom ER Oil Catch Can w/ Fittings and Lines
Deist Transmission Blanket
Apexi AVR boost Controler
GM 3bar Map Sensor
Old Sep 10, 2009 | 05:01 PM
Rawgie's Avatar
Default Re: Fully built Benson Motor plus all my turbo stuff for Cheap!!!!!!!<---
ttt
Old Sep 10, 2009 | 05:10 PM
earlylocks's Avatar
free bump for looking! glws
Old Sep 11, 2009 | 09:58 AM
V3locity's Avatar
part out block? short preferred
Old Sep 11, 2009 | 02:44 PM
JDMInteg96's Avatar
pics... ttt
Old Sep 11, 2009 | 09:52 PM
Rawgie's Avatar
Originally Posted by JDMInteg96
pics... ttt
pics up top
Old Sep 11, 2009 | 10:21 PM
ivt-t's Avatar
not want to part out?
Old Sep 12, 2009 | 11:55 AM
JDMInteg96's Avatar
ttt
Old Sep 12, 2009 | 09:35 PM
Rawgie's Avatar
ttt
Old Sep 13, 2009 | 09:27 AM
carbondc2's Avatar
5grand for everythink is a great deal!
Old Sep 13, 2009 | 05:56 PM
Rawgie's Avatar
I know right! my loss your gain!!!
Old Sep 13, 2009 | 08:48 PM
turbohatch96y7's Avatar
Dealin
Old Sep 14, 2009 | 07:36 AM
99blackdc2's Avatar
PART ME THE WASTEGATE PLEASE
Old Sep 14, 2009 | 11:35 AM
Rawgie's Avatar
Sorry the wastegate and the full race manifold come together due to the fact that a 60mm flange for the wasted gate is welded on to the manifold
Old Sep 14, 2009 | 04:01 PM
b18vtecboi's Avatar
Good deal where are you located? In CA?
Old Sep 14, 2009 | 07:10 PM
Rawgie's Avatar
santa ana
Old Sep 14, 2009 | 08:24 PM
Rawgie's Avatar
Check out the NWP feature on my car witch the setup was in.
http://nwp4life.com/pages/home.htm
click on profile
search for 1996 Acura integra
Rawgie Tagle
Santa Ana Ca.
the car was also featured on Jtuned.com
and Dsport mag.
Old Sep 15, 2009 | 07:15 AM
Rawgie's Avatar
ttt
Old Sep 15, 2009 | 06:10 PM
Stationwagon's Avatar
Bump it up!
Old Sep 16, 2009 | 09:25 AM
Rawgie's Avatar
ttt
Old Sep 16, 2009 | 10:19 AM
4drdohc's Avatar
part out the block? ill buuy it
Old Sep 16, 2009 | 11:06 AM
ALLxMOTOR EG's Avatar
Vietnamese!
Old Sep 16, 2009 | 02:34 PM
Rawgie's Avatar
If anyone is just wondering.....................
Originally Posted by SPOON_BeIgHtEeNsEe
y are u selling? so there is nothing wrong with motor? no smoking or burning oil? what was the results on compression test and leakdown? this is complete running motor and complete turbo kit? would u be willing to do 4000?
This reason why I parted out the car is because I'm relocating to North Ca. for work and the car just sat in the garage. I hardly if ever drove the car. I just had no time for the car and grew out of the hobbie as my son got older and truthfully I could use the money.
I forget the exact numbers on the leakdown test but every cylinder was all in the green. The motor runs strong and is practically bulletproof. When I did this build I did not cut any corners and did everything correct no matter what the expense was. Meaning new water pump oil pump, gaskets, and ect. The motor was put together by John Tan (dan bensons only employee) at bensons when they were located in Orange County. Mike Laskey can vouch for him and my setup.
And Yes this is a complete running motor and turbo kit with top notch parts (quafe, HKS, exedy, ect..)
If you are seriously interested you can come check out the motor and bring a leakdown tester and crank and test the motor yourself.
I don't know about $4k. $5k is a steal already, but money talk and cash is king, so show me the money and we can work a deal out!!
Old Sep 17, 2009 | 11:41 AM
Rawgie's Avatar
ttt
Old Sep 17, 2009 | 06:36 PM
Rawgie's Avatar
BUMP
