Anyone ever have oil leak from this part of the engine?
Old Sep 9, 2009 | 11:57 AM
dgdarien's Avatar
Default Anyone ever have oil leak from this part of the engine?
Anyone ever have a problem with engine oil leaking from this cylinder head seal? (#7 in the photo)
On inspection of my engine it looks like engine oil is leaking from around this seal.
Also does anyone know if its a simple pull out and replace for this part, or does it require access into the cylinder head?
Old Sep 9, 2009 | 12:05 PM
ek-g6's Avatar
Default Re: Anyone ever have oil leak from this part of the engine?
I think you would have to take off the cam cap at where it sits on the cam seal. Then torque it back down when your done, it shouldnt be hard, especially if its a b18a/b engine.
Old Sep 9, 2009 | 12:06 PM
wupike21's Avatar
search cam seal plug, it's one of the most common oil leaks on a b series engine. To replace it simply remove the valve cover and cam cap, make sure to remove and replace the hondabond before reinstalling.
Old Sep 9, 2009 | 01:18 PM
follie gatts's Avatar
yep. just fixed mine. if you can pop that seal out with a screw driver, you have the old style plastic cap plug, which leaks. you can buy a new updated honda seal, or get a neat colored one from the aftermarket.
here's a good write up: http://www.team-integra.net/sections...?ArticleID=576
Old Sep 9, 2009 | 01:37 PM
dgdarien's Avatar
Perfect solution guys. Much appreciated!
Novz
Honda Civic (2006 - 2015)
Apr 3, 2014 05:56 AM
memyth
Apr 23, 2011 10:04 AM
Ron A
Jan 22, 2009 06:02 AM
Semih166
Jan 24, 2008 11:16 AM
svacca1
Nov 16, 2006 04:14 PM
