95mm stroke + 9,000 RPM = Fun
Old Sep 9, 2009 | 11:13 AM
D-Rob's Avatar
Default 95mm stroke + 9,000 RPM = Fun
In case some of you are just now tuning in on this project, this engine is one we've been working on for my father's CRX.
It consists of:
Sleeved 84mm B20 block
Eagle H-Beam rods
CP pistons
Eagle 95mm stroker crankshaft
B16 head
Ported by CC Cylinder Heads (:thumbsup: )
Brian Crower Stage 3 cams
UGR valvesprings/retainers
Skunk2 flat valves
Big-tube Tri-Y header
Thermal 3" exhaust
Victor X intake manifold
65mm TB
3" intake
Tuned on Neptune
We just got the head back on her, and added the 3" exhaust. The old exhaust setup was a 2.25" Tanabe with a 2.5" cutout.
Here's the results
Any questions, feel free to shoot away.
- Derek
Old Sep 9, 2009 | 11:15 AM
KYSI's Avatar
Nil Desperandum
Default Re: 95mm stroke + 9,000 RPM = Fun
Vids? Love the graph
Old Sep 9, 2009 | 11:18 AM
D-Rob's Avatar
Nope, no vids yet.
I may swipe the car from dear ol' Dad one of these nights and make a quick video on the street.
- Derek
Old Sep 9, 2009 | 11:20 AM
00Red_SiR's Avatar
All Motor Mentor
Did you tune it yourself Derek? If so, how long did it take you?
Old Sep 9, 2009 | 11:21 AM
D-Rob's Avatar
Yes, I tuned it just a couple hours ago.
Took me about an hour and fifteen minutes or so to clean everything up the way I wanted vs. the old small exhaust w/cutout tune.
That was with partial throttle touching up rolled in with the WOT stuff.
If it were a brand new map/tune/setup, I usually tune something like this in a span of two and a half hours or so.
- Derek
Old Sep 9, 2009 | 11:25 AM
mikesrex's Avatar
looks good, can't wait to see what it runs at the track!
Old Sep 9, 2009 | 11:28 AM
00Red_SiR's Avatar
All Motor Mentor
Good job on the tuning, the graph looks good. That little car should move pretty well with decent traction.
Old Sep 9, 2009 | 11:34 AM
D-Rob's Avatar
Thanks! The only thing that bothers me about the graph is the hump smack-dab in the middle of the curve, but it didn't seem to want to go away. The only thing I can figure is intake resonance.
The car ran a 12.2 @ 112mph on 22" slicks on the last stock-sleeve 89x85 setup, so we're looking for an 11.9 this year, full interior on pump gas.
The engine also has a 100hp shot of dry direct port nitrous ready to be run, but we'd like to get some mileage on the motor first, as he hasn't had much of a chance to drive it lately.
- Derek
alterdcreations's Avatar
very nice.
Old Sep 9, 2009 | 12:04 PM
d112crzy's Avatar
Over 150ft/lbs at 3k RPMs on a b series! That's ****ing awesome. The torque curve give me a chub.
It looks as if it's asking for more air up top. Gonna try a bigger throttle body?
Old Sep 9, 2009 | 12:14 PM
josh's ep3's Avatar
Function > Form
What were the gains with the 3in exhaust over the 2.25"/2.5"?
We're running 2.5" BC Spec II, and I've been thinking about going with a 3" but I'm not sure if that's too big for her...
Old Sep 9, 2009 | 12:27 PM
egb18c5's Avatar
nice torque, what was the compression?
Old Sep 9, 2009 | 12:45 PM
D-Rob's Avatar
Surprisingly, it picked up the most power down low.
The solid line is the current 3" exhaust, the dotted was with the 2.5" cutout open, with the 2.25" exhaust getting priority in the exhaust routing, and a fair bit of oil being combusted due to some problems our head was having.
The compression is 11.7:1 or so.
The switch to the overall larger exhaust made a few HP everywhere.
- Derek
Old Sep 9, 2009 | 12:51 PM
josh's ep3's Avatar
Function > Form
Oh wow, didn't expect that much of a gain. It should do really good with our compression then...
Old Sep 9, 2009 | 01:15 PM
Notorious92rhdEG's Avatar
what's up D-rob?
what is the peak hp? 248? 249?
am i still holding the all motor 4cyl crown for the shop?
looks great and that CRX is beautiful
ill be calling you in a month or so for another tune on the replacement car.
Blake
Old Sep 9, 2009 | 01:16 PM
D-Rob's Avatar
Originally Posted by Notorious92rhdEG
what's up D-rob?
Blake
248whp/178wtq
And no, sadly your record was broken a couple months ago by another K24 with some more compression, and more revs!
Look forward to seeing the replacement!
- Derek
Old Sep 9, 2009 | 01:23 PM
damn it.... it's on like donkey kong!!
Old Sep 9, 2009 | 01:56 PM
DDTECH's Avatar
derek, you need to get on aim.. got a question.
Old Sep 9, 2009 | 02:04 PM
Sales@Bisimoto.com's Avatar
very nice numbers
Old Sep 9, 2009 | 02:08 PM
D-Rob's Avatar
My AIM account is inactive. LOL
Go ahead and shoot me an e-mail.
madvt3cy0@hotmail.com
It goes straight to my BlackBerry.
- Derek
Old Sep 9, 2009 | 04:12 PM
OH_1fstgsr's Avatar
What is going on from about 7500-9000? The angle of HP curve changes noticeably. Like it is running out of air or the airs not getting out. Or maybe I'm just not use to looking at this type of dyno graph.
Very Very impressive numbers.
Old Sep 9, 2009 | 07:30 PM
lohatch's Avatar
nice job guys! you'll have a blast with that thing!
Old Sep 9, 2009 | 07:47 PM
Combustion Contraption's Avatar
The longer the stroke, typically the more of a nose dive the curve will take after peak TQ has been reached. I would expect this thing to fall off 1000-1500rpm earlier if a stock head was used.
Old Sep 9, 2009 | 09:07 PM
1.5Slowmatic's Avatar
^^would upgrading to a 68 or 70mm TB change this at all?
Bitchin *** numbers D-Rob. If i ever can get a replacement car i would love to make a trip up there for a tune
Old Sep 10, 2009 | 04:14 AM
jdm_ef9's Avatar
Very nice numbers! Very similiar to our 86x89 b-series. Thing should run like a raped ape!
I would recommend getting larger slicks though. At that power/torque level the 22's won't cut it.
