strange alternator issue
Old Sep 9, 2009 | 03:55 AM
thapimpfromchi's Avatar
Default strange alternator issue
I have a b18b in my crx. Originally i had a proper obd1 alternator on there and it everything was working fine. That one went bad, so i bought just any old b-series alt i could find. The one i have on here now works just fine, until i hit about 4k rpm. Once i hit 4k, the battery light comes on, and all my lights dim/flicker, until i get under 4k, then they go right back to normal. Turns out its from a DA. is the alternator going bad, or is it because its obd0? will i be ok, or is this gonna go bad soon too?
Old Sep 9, 2009 | 05:49 AM
Psychoteen101's Avatar
Default Re: strange alternator issue
Sounds like it has a diode that is bad or going bad if the lights are pulsating. Test it to be sure.
Old Sep 9, 2009 | 09:11 AM
ok. sounds good. so, the fact that its obd0 shouldnt be an issue?
Old Sep 9, 2009 | 01:34 PM
8zero8's Avatar
its probably not charging correctly, if its even charging. check to see if the battery is getting charge. it might have some juice in it, but not enough to keep up with the motor at high r's
Old Sep 10, 2009 | 07:08 PM
No that shouldnt really make a difference. Especially if it was working fine before.
88 EF Hatch
Sep 17, 2009 07:29 AM
accrdwgnguy
17
Jan 6, 2009 03:24 PM
C-A
Oct 1, 2007 07:17 PM
whitehf
May 10, 2007 08:40 PM
stocker2shocker91
Oct 23, 2005 05:42 PM
