b18a1 swap in my civic any how to pages
Old Sep 8, 2009 | 06:51 PM
90efcivichatch's Avatar
Default b18a1 swap in my civic any how to pages
going to do my swap in a few weeks just wondering if anybody has any links for wiring and how to do steps for the swap to make it esier thanks
Old Sep 8, 2009 | 07:02 PM
D16SiHatch's Avatar
Default Re: b18a1 swap in my civic any how to pages
search for info pertaining to b-series swaps and have a look at the faq section at the top of this forum. guarantee you will find lots of useful information.
Old Sep 8, 2009 | 07:05 PM
mother ef-er's Avatar
google is a good friend.
Old Sep 9, 2009 | 01:01 AM
EF-Devotion's Avatar
need to convert dpfi to mpfi.
theres other check google.....dpfi to mpfi
http://www.4gcivic.net/wp/?page_id=4
no how to.....google..
just know that you have...
motor..
90-93 axles with intermidate shaft and pr4 ecu... if obd0-90-91...if converting to obd1 92-95 pr4
shift linkage...custom made to fit or aftermarket bought for EF
if you have a std civic like me you gonna need bigger knuckles because std splines for axles won't fit. get integra 90-93 or 88-91 civic or crx si or dx. no hf.
make sure to chop off front motor mount from cross memberance because it gonna be in the way.
may sure you bang the drive side where the alternator sits for clearance....google..
o
make sure you have mount to b-series in EF.
pretty much it... i think. no sequence of i can think of.... do as u like. as long as motor is out and new goes in..first is to take battery out....and dis connect all wiring.
last on motor swap when putting motor in is wiring. as i did.... do what ever you like..
if anything google b18 into ef or ef9
Old Jan 10, 2010 | 05:28 PM
jtwellner's Avatar
hey, I'm putting a b18a1 into my 89 CRX HF this spring and I was trying to figure out what I all needed. I am still a little confused on the axles and knuckles. I have heard I need to replace mine since I have a HF. I do have a 93 Integra as a parts car with axles from it. Can anyone give me the low down on exactly what I need to get and what parts I should we using?
Old Nov 18, 2010 | 11:24 AM
509B18EF's Avatar
on an ef i cannot use the stock DA mounts? and would the SI harness, would it plug up right into the b18 and in the chassies?
catsman50
Jul 10, 2011 06:07 AM
hyrev20
Nov 3, 2008 07:13 AM
Koble
24
Jan 18, 2006 08:30 AM
Ray-mond
Feb 22, 2005 01:32 AM
deviant1
Dec 13, 2002 07:29 PM
