Electrical Issue
Ok so a little backstory and what ive done thus far.
Went out to my car last night and turned the key to start the car, cranked over once and then died. So i took the battery to be tested, AOK. Hmm. Ok so fuses, all are ok...crap.
Checked all the grounds...good getting good connection between all of them (not just the one on the battery). Terminals are all clean as well and all the grounds have been resanded just to make double sure. I also have metered all the fuses, starter, and alternator...the only one to not read 12.7 or 12.6 is the alternator. It was reading 5.7v.
I really would like anyones thoughts on to what this could be....i need my car to get from class to work.
Thanks,,
John
Thanks,,
John
Which alternator wire measured 5.7V and where did you test it?
Do the headlights work?
Do the dash warning lights turn on with the key in ON(II)? Does the fuel pump prime? Does the starter crank the engine but it won't start?
I measured the top one that has the dust cover over it
There is no power whatsoever that comes on in the car. No dome or dash lights. no horn. no headlights, starter,....basicly anything that is electrical doesnt come on.
My thoughts:
Key cylinder (ignition)??
Main Relay?
Alternator?
ECM?
My thoughts:
Main Relay?
Alternator?
ECM?
with the car running, its should read 14Volts (or around there) if the alternator works.
if its not reading that it be be ur alternator.
with the car running,, disconnect the battery(neg.) wire, if the car shuts off, it's the battery. (let it sit a lil bit if it dont cut off right away).
goodluck
goodluck
None of the above. If you have absolutely no power, then start by checking the big 80A fuse under the hood. Is it an 00 Civic?
I have checked all the fuses...refer to original post. It is a 00 civic dx.
I am getting voltage to the fuse boxes as well, im just lost on wtf is happening with it
You dont need a lift, but you will need the car to be on Jack stands since theres a 12mm and 14mm bolt on the bottom of the alternator. One is to support the alternator, and the other is the tension adjustment bolt.
You can pull it out from the top though, but you may scratch your shock tower like I did. You also have the remove the 10mm bolt that holds the P/S hose in place.
By the way, a bad alternator would not stop the headlights and other components from working, though a dead battery would.
It's cool ron, no offense taken. That 80 is checking out fine again...i am getting power to all fuses. I'm going to try and disable my viper alarm system and see if that is my issue.
Thanks thus far to all who are helping me out!
Ok update:
Car is still not functional.
I have changed out the main relay, changed the ecu, and rechecked EVERY fuse. One thing that i did find was that if i wasnt using the battery ground that it was reading 6.3v, not 12.5v with the battery ground.
