HELP: knocking noise when i turn right...
Old Sep 8, 2009 | 03:33 PM
mister.wong's Avatar
Default HELP: knocking noise when i turn right...
hey guys. i need some help.
so i have a 92 civic si hb running on H&R sport springs and stock shocks.
whenever i turn the wheel to the right, i get this knocking/rubbing noise from the front DRIVER side.
initially i thought it would be the cv boots or axels themselves.
checked both sides, no rips or leaking oil on either boots.
both axels are fine, wiggled them a bit, there's a little bit of play but not enough to be a problem...
my brother thinks its the wheel bearing...
i've tried putting the car on jackstands and running the wheels freely but no noise. im assuming because there isn't any pressure put on the wheels...
wat im really asking is; how can i diagnose this problem?
and wat im most concerned about it how severe/important is the problem?
UPDATE:
so i checked the bearing by spinning the wheel manually and shaking the hub. no play when i try to shake it, and no grinds or weird noises when i spin the wheel...
the noise is getting louder now and i'm starting to feel it on the pedals when it knocks...
thanks!
Old Sep 9, 2009 | 02:39 PM
Default Re: HELP: knocking noise when i turn right...
help!!
Old Sep 9, 2009 | 03:05 PM
tsikot93's Avatar
its not a clicking sound?
Old Sep 9, 2009 | 03:08 PM
tsikot93's Avatar
did u check the tire might be rubbing on the front bumper lower cover?
Old Sep 9, 2009 | 03:31 PM
not a clicking sound... more of a low toned swooshing sound...
yeah i checked that as well.. sometimes i get the noise when changing lanes as well, and always when making turns..
keep em coming!
Old Sep 9, 2009 | 04:08 PM
tsikot93's Avatar
keep em coming!
is the pitch change in speed? is your tire choppy/cupping? could be wheel bearing also.. drive your vehicle when u can hear the sound and the swerve (turn your steering wheel left to right)see if the noise will go away?
Old Sep 9, 2009 | 04:28 PM
Linked's Avatar
turn the wheel all the way to the right dead a stop stop> let off the brake and let the car roll with no gas,
if its still making the sound, your not rubbing, you wouldnt have enough momentum to rub on the fender
i would inspect the wheel well, axles,
jack up your front of the car and let it run with the wheels spinning
look for the where the sound is coming from
Old Sep 10, 2009 | 06:24 PM
nope the pitch stays the same .. a low toned swooshing noise... and no the tire isn't cupping.
yeah i did some zig zags left and right before and it only makes the noise when i go right, no noise when i straighten the wheels or go left...
tried both of these... no fender rubbing..
and when i jack up the car and run the wheels freely, no sounds anyhere...
is it possible that the joint is bad even thought the boots aren't ripped or leaking?
Old Sep 11, 2009 | 02:19 PM
tsikot93's Avatar
[QUOTE=mister.wong;39925931]nope the pitch stays the same .. a low toned swooshing noise... and no the tire isn't cupping.
is it possible that the joint is bad even thought the boots aren't ripped or leaking?[/QU
sound like u have a bad left front wheel bearing...coz if u turn to the right u putting all the pressure to the left wheel...its just my opinion its for u to verify...
Old Sep 11, 2009 | 02:20 PM
tsikot93's Avatar
[QUOTE=tsikot93;39935248]
Old Sep 11, 2009 | 02:21 PM
tsikot93's Avatar
Old Sep 11, 2009 | 03:47 PM
ninjasruleyou's Avatar
to check a wheel bearing properly you need to jack that side of the car up, and take the wheel off and then spin it.......that way you can get your ear on it to listen but while you turn it you WILL feel is grinding if its bad in any way, but its best to get both wheels up and off so you can compare the two......just a suggestion
Old Sep 11, 2009 | 05:51 PM
yeah that's what i suspected..
i tried that before and didn't feel anything but i'll try again and be more careful this time...
THANKS!
Old Sep 11, 2009 | 07:21 PM
1FDUPCIVIC's Avatar
It would be really great to know which side of the car it is coming from and I'm assuming the sound is coming from the front :-)
Old Sep 12, 2009 | 10:55 PM
Old Sep 23, 2009 | 08:55 PM
help
it's getting worse!
Old Sep 23, 2009 | 10:13 PM
20civic00's Avatar
axle?...or wheele bearings? try jacking the front tires up and pushing to the top of the tire then the bottom back and forth.check to see if there is any movement, then u know its the bearings. hope it helps
Old Sep 24, 2009 | 01:15 AM
Dub9.Juice's Avatar
i had the same issue your axle might of for some odd reason popped out just a little and u might have to just pull it out and shove it right back in
Old Sep 25, 2009 | 07:04 PM
tried it... no wiggling at all...
tried that too. i tried pulling the axle off the tranny and back on... and dripped oil all over my face *puke*
Old Sep 25, 2009 | 07:24 PM
joelmatt89's Avatar
it is possible for the cv to be bad and you just can't tell however this usually would be noticeable with it running on jacks would say it is probably the bearing. Just try replacing the bearing it's only maybe a 2 hour $40 job at most. I would be surprised if that didn't fix it. If not posting a you tube video may help us help you. Does it sound like it is in tune with the your speed...on faster turns does it click or whatever more and vice verse on slower turns?
Old Sep 25, 2009 | 10:23 PM
94_DC's Avatar
Jack up the car and check EVERY single bolt and nut on the front end. Also a video would help.
michael-crxsi
Mar 30, 2011 04:36 PM
avio
Apr 11, 2010 12:40 PM
PinoyCivic
Jan 17, 2006 06:03 AM
Blastek
Oct 18, 2004 08:34 AM
Sephro
Oct 11, 2002 10:34 AM
