wheel size help
Old Sep 8, 2009 | 01:51 PM
SF_Dee's Avatar
Default wheel size help
93 hatch
stock suspension
i wanna run a 15x7 wheel or maybe 7.5
what off set would be most flush...not sticking out but flush.
and what tires size should i use.
i dont wanna run camber or roll my fenders so, what could i work with..
i might be dropping the car after winter.
Old Sep 8, 2009 | 01:57 PM
SF_Dee's Avatar
Default Re: wheel size help
15x7(.5, 8)+30
15x7(.5, 8)+35
15x7(.5, 8)+40
Old Sep 8, 2009 | 02:26 PM
shailoche's Avatar
I am currently running a set of Honda Fit HFP 16" rims with 205/40/16 tires. The rims have a +45mm offset and are approximately 6.5" wide. There is no rubbing at all on the tires and they sit almost completely flush with my wheel wells. I am driving a 1993 Del Sol Si...so, if you have a Del Sol you could easily run a 15x7 +45mm offset and they would work.
With a standard Civic I think they have less room than my Del Sol. So, that would mean you would have to run less offset. I wouldn't go further than +40mm offset on a stock Civic.
So, I would estimate that you could easily run a +40mm offset on a 15x7 rim without having to roll your fenders or run adverse camber. Keep in mind that in order to run without rolling your fenders you can't fit your wheels all the way flush with the fender. You have to leave a few millimeters of clearance to allow for the wheels to move freely with the suspension travel.
SilentSleeper93
Oct 23, 2012 02:58 PM
JdelMsolG
Aug 22, 2006 11:53 AM
deadlock32
Nov 29, 2005 12:55 PM
s2kds
Jan 3, 2004 03:11 PM
phantom_sol
Jul 26, 2003 12:12 PM
