Strange brakes problem
Old Sep 8, 2009 | 08:03 AM
EJ1_Sleeper's Avatar
Default Strange brakes problem
I've got a 89 hatch. Rebuilt the rear drum brakes with new wheel cyls, shoes and hardware. Go to bleed them and we loose brake pressure.
Run around in circles bleeding the brakes (all 4 corners and even the master) and still nothing. Discover that the calipers (both) piston seals were shot.
Replaced with reman caliper, pads, and replaced the master cyls gasket going to the booster (was shot). We got some pedal feeling back and the car stops now, but it has a very low brake engagment. Only thing that wasn't replaced was the brake booster. All lines are fine, nothing leaks, no air in any of the lines. I need to help here I'd like to have proper brakes again.
Old Sep 8, 2009 | 09:21 AM
4drEF's Avatar
Keyboard Humorist
Default Re: Strange brakes problem
Rears are drums, right?
Did you manually adjust them before testing them out?
I click the emergency brake one or two clicks and then manually adjust the shoes until I get drag of the shoes in the drum. Release the E-brake and it should spin freely again.
Make sure you bleed the brakes in the proper sequence - it does matter.
Passenger rear, driver front, driver rear, passenger front.
Old Sep 8, 2009 | 12:09 PM
all of that has been done, still the same results. Me and a certified mechanic worked on it. work was just done at my house. still has the same poor brake feel.
94 IntegraLS
21
Jun 11, 2012 08:41 PM
spens 91 Ef
10
Apr 19, 2010 09:55 PM
flowgetta
Apr 16, 2009 12:09 PM
hamadiscool
Aug 8, 2006 09:33 PM
GQ Cowboy
Jul 21, 2002 10:58 PM
