vibrations
Old Sep 8, 2009 | 07:47 AM
8VEYBEYB's Avatar
Default vibrations
I have an auto 95 dx ,
when I am idleing in D (does not have an issue in Park) My car vibrates enough to make my muffler rattle and my driver side door rattles too. ESPECIALLY with the brakes on.
I have tested to see if I have any vaccuum leaks because there is a whining sound when going from 20- to a stop , no leaks to my knowledge .
My question is , what does this sound like to you?
because It almost seems like my break booster is the culprate. thats where the vibs are coming from anyway it seems like its near the drivers side firewall. my brakes are kind of weak but I deal. I was just wondering what else might cause this? my mount seems to be fine as well. any input is mucho appreciated.
thanks.
Old Sep 8, 2009 | 07:55 AM
90Rexx's Avatar
Default Re: vibrations
maybe you have a loose heat shield on your muffler? is the car actually vibrating excessively or are there just vibration noises coming from specifiic points in the car?
Old Sep 8, 2009 | 07:56 AM
8VEYBEYB's Avatar
deffinately actually vibrating. specifically coming from the firewall it sounds like its right behind the steering wheel. IE why I think it might be the booster.
Old Sep 8, 2009 | 07:58 AM
90Rexx's Avatar
mmmm... check for broken or damaged motor mounts and torque mounts then
Old Sep 8, 2009 | 08:00 AM
8VEYBEYB's Avatar
did that but I mean if its broke I would imagine it would do it in park too. I cant see any dmage with the naked eye.... I mean no cracks or anything is there anything else to look for on a messed up mount.
Old Sep 8, 2009 | 08:27 AM
90Rexx's Avatar
withought getting too into NVH, your car idles at different speeds depending if its in park or nuetral or drive, everything resonates differently. so depending how much vibration there is something may make noise, or it may not. so at different idle speeds, somethings may make noise and others not.
that was a really bad explanation but u get the idea...
wodiej
Aug 20, 2017 04:07 AM
skate1968
Jan 23, 2009 03:58 PM
biggjerryc
May 25, 2008 07:06 PM
ej one
Jan 11, 2004 07:49 AM
garados
Mar 29, 2003 04:10 PM
