PA SEPA Beautiful Boosted Type R Coupe For Sale or Trade for WRX or STI
Turbo Kit
Turbo XS RFL (Black) Blow off Valve
Equal Length tubular turbo manifold
Custom 2.5" downpipe (Heat Wrapped)
Polished Intercooler Piping
T3/T40e Turbo
Cyclinder Head
70mm Professional Products Type R Throttlebody
Supertech Nitrate Valve Seals
Supertech Titanium Retainers
Skunk2 Dual Valve Springs
Skunk2 Pro2 cams
P30 Intake Manifold
B16 (pr3) Head
Skunk2 Billet Cam Seal
Block
Honda New OEM Piston Rings
Nippon Racing Performance pistons 9.48:1 Compression Ratio for this setup
ACL Rod Bearings
Honda OEM Main Bearings
Moroso Oil Pan
Cometic Head Gasket
ARP Head Studs
Car
New Brakes
New Rotors
New Calipers
New Hubs
New Ball Joints
New Tie Rod Ends
Brand New Konig Heliums
Brand New Falken 502 (0 miles)
Pacesetter Exhaust (muffler is removable and have a strait pipe that can be slipped on
High Flow Cat
Fidanza Short Shifter
Aluminum Radiator
Flex-a-Lite Fan
Gates Racing Blue Radiator Hoses
Black Front GSR Cloth Seats
HID Headlights
IPCW Black Housing 1 piece Projector Headlights
Suspension/DriveTrain
Brand New Axels
GSR Transmission
ACT Full Clutch Kit Sprung Hub
Full Energy Suspension Bushing kit installed
Omni Pro Drag Fully Adjustable coil over suspension kit
Omni Front Upper Adjustable Control Arms
Front Upper Strut Tower Bar
DC Sports Rear lower Tie Bar
Megan Blue Rear Lower Control Arms
Skunk2 Rear Upper Strut Bar
Fuel
Walboro 255lph Fuel Pump
460cc Injectors
B&M Fuel Pressure Regulator
Ignition
Msd Ignition distributor cap
Msd Ignition distributor rotor
10.2mm Sparkplug wires
Msd Ignition Blaster 2 Coil
Msd Ignition 6AL
Ecu/Electronics
Blitz Electronic Boost Controller
GM 3BAR Map Sensor
Socketed P28 with quick release for quick change of chips for different tunes
Misc
Russel Liquid filled fuel guage
Autometer Cobalt Boost Guage
Weapon R OverFlow Tank
Blox Oil Filter Adapter
Hood Release Cable is Tucked inside the frame rail (This is the new thing for theft they pop your hood with that cable through the wheel well and take all yo **** happened to my friend)
This is a quick run down of a parts list I am sure I am missing something. This is *WireTucked* Running on low boost right now (6psi). Its a fast car pulls hard. I never drive it. Looking for a wrx now need a 4 door getting married on sunday. Lifes over!
Oh Cracks in windshield should be replaced.
I have a deal set up with a friend for a 2004 wrx for 6700 so thats what I am listing the car at. 6700 is a great deal you couldnt build this car for anywheree close to that. Or I will trade for a wrx SEDAN 5spd even up.
www.thestreetmafia.yolasite.com
T3/T40e Turbo
Cyclinder Head
Skunk2 Pro2 cams
P30 Intake Manifold
B16 (pr3) Head
Block
ACL Rod Bearings
Moroso Oil Pan
Cometic Head Gasket
ARP Head Studs
Car
New Brakes
New Rotors
New Calipers
New Hubs
New Ball Joints
New Tie Rod Ends
High Flow Cat
Aluminum Radiator
Flex-a-Lite Fan
HID Headlights
Brand New Axels
GSR Transmission
Fuel
460cc Injectors
Ignition
Msd Ignition 6AL
Ecu/Electronics
GM 3BAR Map Sensor
Misc
Bump Must sell ASAP before i miss out on my wrx. need my down payment this is a deal! you couldnt build this for anywhere close to this price.
I know my buddy has almost the exact same set up except he has pro 3 cams and its on a b16 and on 22psi with race gas he made 478whp but as a daily its at 15psi making 386whp
if i dont get an offer this week the car is getting completly finished tuned and going up to $9000.00 or ill keep it and just look at it lol
A guy is coming to check it out tonight and i am tired of getting shitty $5000 offers the price is 6700 firm!
