FS: Fully Built LS/V, Liberty Gearset, Dig 7 Plus Prog, 94 GSR shell w/cage-chute ETC
Motor is as follows: $3000+shipping!!!! Will Come with everything listed below.
Motor has 7 passes and 1 dyno session. Made 773HP@30PSI.
LS block
GE Sleeves w/Orings
CP 84mm pistons with upgrades wrist pins (flat tops 10:1 cp)
Manley rods (LS)
LS crank
Clevite Bearings
OEM Oil/Water pump
LS oil pan Tapped
GE LS/Vtec Kit
GE 84mm head gasket
GSR Head
Fully Ported and Polished by Ryan@Warr heads
GSR Cams
Supertech Springs/Retainers
Supertech Inconel Exhaust valves
Bronze guides
Valve Job
High Amp Alternator
**Mounts/Trans/Scatter Shield/Breather Kit/Fluidamper/Wiring Harness/Intake-TB NOT Included!**
Taking interest in parting out the block and head seperate. Let me know if your interested in either.
LS OBD1
***Will Sell Distributors seperate for $130 shipped each.***
Del Sol Dual Core Radiator w/slim fan $100 shipped
Full Racing Suit $250 shipped
Shroud Pants - SFI Cert 3-2A/5 - Large
Shroud Jacket - Double lined SFI Cert 3-2A/5 - Large
Simpson Shoes - Size 12
Shroud Gloves - SFI Spec 3.3/1 - Medium
Shroud Neck Brace - SFI Spec 3.3
Paypal address is SupraTT_T78@hotmail.com
Jason
801-879-4940.
I do have texting so. Text me if ya got questions.
LS block
GE Sleeves w/Orings
Manley rods (LS)
LS crank
Clevite Bearings
OEM Oil/Water pump
LS oil pan Tapped
GE LS/Vtec Kit
GE 84mm head gasket
GSR Head
GSR Cams
Bronze guides
Valve Job
High Amp Alternator
LS OBD1
Jason
801-879-4940.
