what oil should i use on a fresh rebuild first start up!
Old Sep 7, 2009 | 10:37 PM
superhatchbackbros's Avatar
Default what oil should i use on a fresh rebuild first start up!
hey honda tech member! i got a few questions for ya's! please help me with the best of ur knowlege thanks in advanced!
ok i build a ls/vtec! 18a1 bottom ende all machined ETC! and a jdm b18c gsr head! i have the mtor fully built and i was wondering what motor oil is best for the first start up! i was told u run the car for 20mins on 2000rpms and then drain the oil and change filter! and check for anything in the oil! if nothing u put new oil again back in it and ur good and then break the engine in after 500-600 miles! and not shift higher then 4500rpms and never hit vtec!
ok soo as i asked whats the best motor oil?
mobile 1 full synthetic 5w30?
or just something not synthetic?
whats the best for a ls/vtec?
also how many liters or quarts does the ysk-1 lsd tranny take?
whats the best brand to buy? i heard pennzoil syncromesh was good? and info on this?
ok thanks in advanced honda-tech members on helping me!
Old Sep 8, 2009 | 12:49 AM
Mindgamez's Avatar
Default Re: what oil should i use on a fresh rebuild first start up!
On my Builds I've Always used NON-SYNTHETIC for the first 1000 miles. Than royal Purple for the next 1000 than i switch to mobile 1 full synthetic 5w30.
As for ysk-1 There is no tranny by that name. Its actually stamped on all the transmission cases. Its Either ys1, A1, or S1, and i recommend HMTF. As for how much just fill it up till it starts pouring out... About 2 1/2 - 3 quarts.
Old Sep 8, 2009 | 01:57 AM
Ruben19's Avatar
i used regular castrol 10w30 my fist 5k then i switched to full synthetic
Old Sep 8, 2009 | 05:21 AM
ok thanks! anyone else? bump TTT
Old Sep 8, 2009 | 07:23 AM
Muckman's Avatar
Moderator in Chief
I use the cheapest non synthetic oil. The cheapest oils are the only ones that do not have detergents and additives which you dont want/need to break in a new engine. I also change it after the first test drive with more cheap oil.
Old Sep 8, 2009 | 09:30 AM
CleanLikeJdm's Avatar
Hype-R Stalker
Old Sep 8, 2009 | 09:34 PM
BUMP TTT
MUGEN182
16
Mar 26, 2010 08:29 AM
nicoya_hyphy@yahoo.com
Oct 3, 2007 05:24 PM
climb_on
Jul 15, 2007 04:05 PM
lsturboswap
56
Apr 23, 2007 08:32 AM
psegs80
Aug 16, 2005 11:24 PM
