timing belt tensioner nut stripped
Old Sep 7, 2009 | 09:57 PM
pinkda9's Avatar
Default timing belt tensioner nut stripped
with the motor in the car I tried to do my friends timing, but his belt tensioner is stripped out what should I do.
Old Sep 8, 2009 | 07:38 AM
9KRevLimitDC2's Avatar
Default Re: timing belt tensioner nut stripped
Try using an appropriate sized socket that is designed to grab stripped bolts.
Old Sep 8, 2009 | 07:41 AM
Jimmy's Avatar
Global Moderator
^ I agree.
A company named ''Irwin'' makes some good sockets for this or just go to the parts store and look around.. It should work
Old Sep 8, 2009 | 09:11 AM
SuzukaBlueAP2's Avatar
while you are trying to do that, order a replacement bolt from Honda.
if you can't get one of these sockets on it, you may have to use a pair of vice grips to get it loosened and out.
bdlawnic
Oct 6, 2013 11:58 AM
methos713
May 5, 2008 08:01 PM
mattatchison
Jun 7, 2007 04:58 PM
Luserkid
Apr 10, 2003 06:41 PM
SilverEk3dr
Jan 29, 2003 11:27 AM
