92-95 Civic 5 speed swap parts, EX trans, and more!
Parting out a 1995 Civic EX coupe, 5 speed. Everything is available and will be ready for pickup this coming weekend.
EX/SI SOHC trans, great condition, only has a slight grind going into second at high rpm's. SOLD
Every part needed for an auto to 5 speed swap, except for the axles and throttle cable. $120
Complete power option package, power windows, locks, and mirrors. Includes all the harnesses, switches, motors, black door panels (with OEM tweeters) and mirrors needed. SOLD
Front mudflaps, great shape. Sold
Ignition switch assembly and complete lock set with one key. $40
Black steering wheel and airbag. $35
Black front seats, faded a bit. $50
AC system parts, anything you need. $cheap
D15B7, needs a HG, leaking water into cyl#1, and missing the dizzy. RUNS! $50
Passenger coupe/hatch door, great shape, flat black. $25
Rear bumper, teal in color. SOLD
EX front knuckles with big brakes, take them with calipers SOLD
Coupe/Sedan OEM outer tail lights, in great shape. Take them both for $20
Passenger side headlight, good shape. $20
Both side skirts. $30
Black belts, decent shape. $40
Tilt column. $20
Anything I haven't mentioned here you need, let me know. The engine, ECU, and cluster are unavailable. PM me as I don't get on here often.
Tilt column. $20
I might be interested in the dash. and a TON of misc stuff...
How's the trunk/rear bumper? trunk trim all intact?
Rear trailing arms are they rear disk or drum? either way how much?
Now is the time to make requests for anything still on the car, as its going to the crusher next week
Shell with complete sunroof swap (sunroof assembly, wiring, relays and switch) Available for cheap. You haul away, bring a trailer or flatbed. Shell still has all glass in great shape. Hell of a deal.
