FS:K-SERIES CHANGE OVER EG,DC REV-HARD
SOLD TO A GOOD FREIND UP IN VA IT ALL WENT TO A GOOD HOME.
!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!DEL ETE THREAD!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!
HEY WHATS UP EVERYONE I AM JUST WANTING TO SEE WHAT KIND OF MONEY I CAN GET OUT OF THIS WHOLE PACKAGE DEAL.THERE IS ALOT OF REALLY NICE PARTS THAT COME WITH IT AND ARE LISTED BELOW.
I WILL NOT PART OUT. I WILL SELL THE SWAP AND THE TURBO KIT SEPERATE THOUGH
PRICE'$ $10,000 OBO WITH TURBO KIT OR $9,000 OBO WITHOUT TURBO KIT AND RC 550 INJECTORS
MEANS OF CONTACT: PM ME ON HERE OR CALL (910) 284-8409 OR (910) 665-1179
SERIOUS BUYERS ONLY (DEPOSIT BEFORE U PICKUP)
I HAVE ALL RECIPTS FOR EVERYTHING LISTED ALL LEGIT
USDM K20A2 SWAP WITH LSD PACKAGE DEAL TO GO INTO EG DC WITH 30,000 MILES ON IT
THE MOTOR HAS 30,000 MILES ON IT SO DOES THE TRANNY BOTH ARE IN EXCELLENT SHAPE NO GRINDS IN THE TRANNY SHIFTS SMOOTHLY,THE MOTOR IS ALSO IN VERY GOOD SHAPE DOESN'T BURN OR LEAK ANY OIL,WITHIN THE LAST 2 YEARS IV OWNED IT I HAVN'T EVEN PUT 4,000 MILES ON THE WHOLE SWAP (SOLD AS IS NO REFUDNS)
K20A2 FULL SWAP INCLUDES
[B]FULL SWAP MOTOR AND 6SPD LSD TRANS
ACT STAGE 3 CLUTCH KIT WITH 7.8LB FLYWHEEL(INSTALLED ALLREADY)
QUAIFE LSD (INSTALLED ALREADY)
OEM AXLES
EP3 IDLER PULLEY
SHORT RAM INTAKE WITH K&N FILTER
STOCK FUEL INJECTORS
STOCK FUEL RAIL
ALL BOLTS AND HARDWARE TO INSTALL SWAP
K20 i - VTEC INTAKE COVER BLK
KARCEPTS SHIFTER MOUNTING ASSEMBLY
SHIFTER BOX WITH CABLES
MUGEN OIL CAP
BRAND NEW THROTTLE CABLE FOR K SWAP
CLUTCH LINE FOR K SWAP
RSX 6 SPEED SHIFT ****
UPPER RADIATOR HOSE WITH COOLANT TEMP SENSOR ADAPTER (POLISHED)
HASPORT MOUNTS
HASPORT OR HYBRID RACING SUB HARNESS
ENGINE HARNESS WITH CHARGING HARNESS AND FUSE BOX
HONDATA K - PRO(WITH SOFTWARE)
SPARK PLUG COVER (OEM BLK)
GOLDEN EAGLE FUEL RAIL (POLISHED)
RC 550 CC INJECTORS
SUMMIT STAINLESS STEEL BRAIDED LINES WITH AN FITTINGS RED/BLUE
NO NAME FUEL REGULATOR POLISHED
B&M FUEL PRESSURE GAUGE MOUNTS ON TOP OF FUEL FILTER
BATTLE GROUND RACING 4-2-1 STEP HEADER WITH 2 1/2 INCH COLLECTOR NOT OVER 1,000 MILES ON IT
REV HARD STAGE 2 TURBO KIT
Turbo Manifold is a cast top mount manifold
Precision Turbo Specs: T3/To4e 60trim/63 AR Hybrid
Intercooler Piping: 2 1/4 and 2 1/2 painted universal gold
Intercooler: Rev Hard fits perfectly behind bumper grill a little trimming required on a eg
Intercooler couplings: Qty 9 or 10
Bov: Vortec polished
Down pipe: 3 inch heat wrapped
Boost Controler: No name manual
T- Bolt clamps: Qty 22 just paid $100.00 for these
Boost Gauge: Auto meter carbon fiber series
Vacume lines: some blue some blk
Wastes Gate: Tial 38 mmm polished
Waste Gate Dump Tube
Turbo feed line with brass T for oil sending unit
Oil return line Home made u can have it if you want it
Good: Is that this is a nice turbo kit not a cheap on and it makes good powwer,
mine made close to 300hp to the wheels on 8 psi and that wasn't a real good tune.
No shaft play on turbo only has about 3,000 miles on the kit at the most doesn't smoke a bit,and the manifold wont break.
Eff.To 450 hp this is not the hypo kit it is the stage 2
Bad: Only bad thing is there is a very small ding on the front of the intercooler but not to worry it was leak tested.
And the only other thing is the reurn line is homemade could use a AN line,never came off on me though.
OEM AXLES
EP3 IDLER PULLEY
STOCK FUEL RAIL
MUGEN OIL CAP
HASPORT MOUNTS
RC 550 CC INJECTORS
darkDB1
Aug 26, 2009 11:19 AM
Eurorider1
Jul 16, 2004 04:42 PM
