Please help me wire vtec on my D15B
OK guys, first thing, I'll try to keep this easy to read, but I need REAL help, so read the whole thing. Please do not read 5 lines and then post a link and leave.
I just swapped my motor to a D15B w/vtec. I currently have a 92 DX sedan. I already got the P08 ECU.
Now I've gotten a hold of some diagrams and pinouts that explain what to do. The problem is, according to my diagram pictured below I need to plug the Vtec solenoid into pin A4 in the back of the ECU. No biggie right?
Well that's where I ran into my first problem. In the picture below, you can see my A plug. The wire 2nd from the left (orange with white stripe) is already plugged into A4.
So from there I looked to the pinout i have. According to the pinout, the orange wire with a white stripe that is plugged into A4 is the VTS. My question is what is the VTS? What do I do with this?
If your car is a 1992 then the V-TEC wires are already run to the shock tower. All you need to do is run your wires from the shock tower to the V-TEC solenoid and the pressure switch.
I think you may very well be correct.
As you can see in this picture, the orange wire with a white stripe that connects to A4 doesn't run to anything.
The orange wire with a black stripe also doesn't run to anything.
ilovemyb16a
May 18, 2006 12:58 PM
sethm
Dec 7, 2003 08:57 PM
