Head gasket???
Old Sep 7, 2009 | 04:02 PM
jlow125's Avatar
Default Head gasket???
This morning I tried to start my car but it wouldnt fire so I checked the plugs and found a large quantity of oil in the fourth cylinder. Ive been losing large quantities of oil for a few weeks now. Would this be the head gasket or the valve cover gasket?
Thanks in advance
Old Sep 7, 2009 | 04:05 PM
Apathy47's Avatar
Default Re: Head gasket???
if you had a blown head gasket, you be seeing white milky substance on the oil cap and dipstick, similar to this:
Old Sep 7, 2009 | 04:17 PM
TwotoneC1Da9's Avatar
do u see any leaks?? start by replacing the vc gasket set. If your still burning oil get a compression check done. and how many miles on the engine? could be bad valve seals or even piston rings
Old Sep 7, 2009 | 04:24 PM
mikeSONICGSR's Avatar
I had this problem, the seals that I got were cheap. Check the 4 seals for the spark plug tubes, most likely the problem.
Old Sep 7, 2009 | 06:41 PM
jlow125's Avatar
now the spark plugs are not sparking at all. could it be the distributor coil?
Old Sep 7, 2009 | 07:02 PM
if it got spark b4 u pulled the plugs double check the firing order
Old Sep 7, 2009 | 07:29 PM
jlow125's Avatar
it was not firing before i pulled the plugs. that is why i pulled the plugs and found the oil.
Old Sep 7, 2009 | 08:00 PM
have u recently replaced anything? how many miles on the car and what symptoms did u have before it stopped starting?
Old Sep 7, 2009 | 08:54 PM
bigislandc2's Avatar
if there is no spark that is where you problem exsist. even if there were still oil in plugs vehicle will still start. more then likely it is youre ign coil. but do youre checks, as far as oil leak replace valce cover gasket first and recheck. youll know if youre headgasket is leaking.milky oil miss fires. etc
jdm mini me
10
Mar 25, 2010 09:04 PM
projcinco
Aug 28, 2008 06:10 PM
Dorksk8tr3
Aug 18, 2005 09:46 AM
diewX3
Feb 24, 2005 04:08 PM
1.8Tea
Aug 27, 2004 07:54 PM
