94 b20b with gsr tranny no start
so im driving my car to my friends house i turn it off and we stay there for awhile i go bak out turn the key and nothing no crank just a dead car any ideas?? check sum fuses all good idk wat it is man!! help THANKS HT
i said everything in the car works the fuel pump primes all the dashboard lights go on and everything..... We do clutch start it and it turns on and drives perfect so i dont know...but where is that clutch pedal switch located???
At the top of the clutch pedal, there is a switch that activates the starter solenoid circuit when the pedal is pushed down. A common cause for a no-crank problem is that this switch breaks.
well we removed the starter and put it back on just incase and still nothing im guessin i should change it but i wanna be sure if it mite be that
Well are you getting amperage to the starter? Cause if you doesnt have enough it wont turn the starter over? Maybe the Diodes have gone bad in the starter comin problem (if OEM starter) had it with mine.
well yea its oem starter and we dont have a amp meter so how do we check it another way??
and umm the pedal switch how do we know if its gone bad? and the plastic is there also
[QUOTE=teamrpm2;39889757]well yea its oem starter and we dont have a amp meter so how do we check it another way??
no volt meter he did say i believe though..
I think you mean the windings because there are no diodes in the starter. There are diodes in the alternator.
