prelude throttle or blox?
i looking at a prelude throttle body and a blox 66mm throttle body come with blox tps sensor (pro series i think on tb)
i can get a prelude throttle body this friday for 50bucks, i think is 62mm? i have a skunk2 manifold with 64mm opening. or should i spend the money get the blox is 250bucks
The Skunk2 is 64mm from the gate. With no porting! If you "port the crap" out of the prelude Throttle body you still will not see the full potential of the S2 Manifold.
the blox may cost a Nutt but It is worth it at 66mm Then
port the S2 manif to match and you are
i'm confuse now, get prelude one or dont get it?
i lost power with 56mm stock tb with the skunk2 manifold(lost low and mid but gain a a lot at the top which don't help me none), so i'm little worry going with the bigger tb. anybody have a good gain from mani and tb combo with b16?? also plan on running type R cams in few weeks.
now i think about it, your right. if its brought up in a conversation, then go ahead and do it the right way
