Steel Braided lines - any reccomendation?
IM going to buy a set of lines for my EK.
Currently using Spoon Twin Block calipersa and endless CCx pads.
What brand do you reccomend?
Earls
Goodbridge
Russell?
Any other?
Thanks in advance
Earls
Goodbridge
Russell?
Any other?
Thanks in advance
Comptech used to rebrand Goodridge lines, if that adds any confidence to their quality.
2 years on my Comptech/Goodridge lines so far without issue, but like all SS lines need to be replaced frequently. I'll be replacing mine soon, and probably with the same brand since they help up fine.
i have some techna fit lines for 20 bucks for ek, liked them very much.
i got rid of my booster so i ended up making my own ss braided lines from the master cylinder to the caliper so thats why im selling them.
Because unlike the rubber OEM lines, they were never intended for extended use.
Braided steel will allow dirt under the weave, eventually, next to the teflon inner line, where it will rub a hole in it. The only questions are when and how badly. regular inspection and replacement are simply the burden of choosing to swap to steel lines.
And since they offer no braking advantage (only feel), only make the change if you're willing to deal with the downsides.
Yes, if they actually need to be replaced.
Rubber lines seem to last nearly forever. I have a 30 year old car still running its original rubber brake lines without issue (and its British, so they're quite possibly the only original parts still left on the car).
Yes, sometimes. How much difference, I can't say, as it depends on many factors including the condition of the existing lines.
If you're looking to improve the braking feel, consider what pads are on the car, and what condition the rotors are in first. Also consider just trying a fluid flush if it hasn't been done in a few years. My opinion anyway.
whats the difference in the 2 brake lines? say i got ss brake lines and put like a wire loom or something of that sort around them, will they need to be replaced frequently?
steel lines are not install and forget items. oem rubber lines are actually pretty good. If yours are old and you don't want regular maintenance, just put new oem rubber lines on.
If you get stainless lines, get some that have a protective coating/sleeve on them. Prevents dirt getting into the braid and reduces likelihood of premature failure. You could use heatshrink, wireloom, etc., but I wouldn't recommend it. You want something clear so that you can easily *visually* inspect the line.
On a historical note. Stainless steel brake lines were not created to improve braking, pedal feel or anything like that. They were created to prevent race cars from getting their brake lines cut from debris on the track.
civexspeedy
Jun 9, 2008 08:54 AM
fso_BamBam
Apr 13, 2004 01:50 PM
onyx00
Jul 9, 2001 06:00 PM
