Compression Test
Old Sep 6, 2009 | 05:36 PM
Bonestock98GS's Avatar
Default Compression Test
Well My setup was told to me as I bought the car as having 12:1 compression and stock GSR rods. GSR block and B16 head. Head is Stock. We did a compression test and we got 240 all across the board. My friend was telling me to ask you guys if 240 across the board meant that it has those 12:1 pistons or is this motors block completely stock? I need help with this question ASAP because I am going to boost by the end of the week thanks
__________________
Old Sep 6, 2009 | 05:39 PM
DDTECH's Avatar
Default Re: Compression Test
i had 11.8~12.0 CR on my itr, and i was getting almost 260 psi across the board..
You have a healthy motor.. CR will vary.. depending on the setup and what not..tho.
The pistons that were used could say 12.1 CR in a ls/vtec because of a ls crank
if you put those into a GSR witha gsr crank obviously and gsr rods, you will drop your CR to around 11.6~11.8 depending on the support mods as well.
Your numbers are fine.
Old Sep 6, 2009 | 05:42 PM
Are thy good enough to throw a turbo on with a very nice tune and make decent power?
Old Sep 6, 2009 | 05:59 PM
DDTECH's Avatar
This is a all motor forum.
Against better judgement, i wouldn't turbo a motor with that high of compression..
Old Sep 7, 2009 | 12:02 AM
boxeocampeon's Avatar
The compressions hella high i would watch turboing it
Old Sep 7, 2009 | 07:03 AM
95 integra's Avatar
As with all things you buy used, you always have to inspect for yourself because typically the previous owner didnt really know wtf they had. 240psi would generally mean 11.0:1 compression range, however, it very well could have 12:1 and have semi-worn rings or big cams (which the overlap will take off some compression). Thus, you cant be sure using a compression check like you are. Look down in the spark plug hole and see what type of dome you have on the pistons....typicall that will give you some idea (or atleast it does with me since I've seen a good many pistons in my time).
Old Sep 7, 2009 | 12:43 PM
when we checked the dome looked as if it was triangular shaped. The Spark plugs were white which means its running lean right? I know this is All Motor I am asking you guys becuse right now I am All Motor and wanted to know if my compression sounds igh like I was told.
TravisBiggie
Feb 23, 2015 01:11 PM
Boosted_B_Series
Feb 13, 2009 07:45 AM
boostd ls
Dec 7, 2005 08:29 AM
steelies
Aug 23, 2005 06:21 AM
NightmareApex
Nov 29, 2004 07:15 PM
