Master Cylinder Question: What the difference btw. these two?
Old Aug 27, 2002 | 05:13 AM
Ricky Rojales's Avatar
Default Master Cylinder Question: What the difference btw. these two?
What's the difference btw. master cylinder #1 and 2... my GSR has #1. The search on the
http://www.acuraautomotiveparts.net site yielded these results.
Also, my pedal sinks slowly and I would like to know what seals, parts etc. I could replace short of purchasing the entire master cylinder assembly? Any insight or suggestions?
Thanks in advance.
[Modified by Vicious Cyrcle, 9:28 AM 8/27/2002]
Old Aug 27, 2002 | 06:39 AM
b18bvtec4drteg's Avatar
Default Re: Master Cylinder Question: What the difference btw. these two? (Vicious Cyrcle)
Not sure what the difference is. The one on the left looks like mine and I have ABS. Not sure on the one to the right.. maybe without ABS. Yeah if your pedal starts sinking, you can try to re-bleed the lines. If that doesnt work then your master cylinder is shot.
Old Aug 27, 2002 | 06:54 AM
Tweakmeister's Avatar
looks like the main difference is where the lines are.
my '99 has #2
try getting an MC Brace...this is one of those mods that no one talks about but does worlds of difference.
Old Aug 27, 2002 | 07:09 AM
dnt94civic's Avatar
Default Re: Master Cylinder Question: What the difference btw. these two? (Tweakmeister)
There is really no difference between the two. like Tweakmeister said, just the lines.
MC #1 are the older style MCs, and MC #2 are on the newer 99+ i think.
I would love to get a MC brace too, but don't know where?
Old Aug 27, 2002 | 07:24 AM
Default Re: Master Cylinder Question: What the difference btw. these two? (dnt94civic)
That makes sense. Thank You.
Old Aug 27, 2002 | 09:22 AM
fuguman's Avatar
New User
what does the brace do?
Old Aug 27, 2002 | 09:40 AM
Default Re: Master Cylinder Question: What the difference btw. these two? (fuguman)
It isolates the MC and booster and stiffens the structure, thus improving pedal feel and decreasing flex at the firewall. Some individuals will debate it's effectiveness, but it's an additional benefit to those people who've already done the brake MC upgrades, fluids, pads, etc.
Check/ Search the ITR forum for more info.
HTH
Old Aug 27, 2002 | 09:47 AM
fuguman's Avatar
New User
thats where i read it the first time but didnt get how it would help
Old Aug 27, 2002 | 09:49 AM
PaChiLa Leader's Avatar
Would it be brake cylinder and Clutch Cylinder>=?
just a thought
as far as i know, doesnt' matter which one you get, B-Series should bolt right on.
i have a 00 model with 96 rebuilded GSR clutch master cylinder and brake cylinder.
Old Aug 27, 2002 | 09:55 AM
Default Re: Master Cylinder Question: What the difference btw. these two? (PaChiLa Leader)
To Clarify: Brake MC... sorry.
Old Sep 2, 2002 | 09:04 PM
Vitt1's Avatar
as far as i know, doesnt' matter which one you get, B-Series should bolt right on. i have a 00 model with 96 rebuilded GSR clutch master cylinder and brake cylinder.
Hum, I don't know. I bought a new ITR MC and went to put it on my 94 GSR only to find out that the mounting points on the booster are different. The new one's mounting points are horizontal, but the ones on my 94 GSR are tilted, maybe 4 o'clock and 1 o'clock.
Old Sep 2, 2002 | 09:28 PM
IN VTEC's Avatar
Default Re: Master Cylinder Question: What the difference btw. these two? (Vitt1)
It's kinda evident on the parts diaghram also if you look at the two master cylinders where the bolt patterns are at.
It's in the '98+ models that have the non-round reservoirs.
Old Sep 2, 2002 | 09:50 PM
Vitt1's Avatar
Default Re: Master Cylinder Question: What the difference btw. these two? (IN VTEC)
Well, I hadn't looked at the diagram, I just bought it from a H-T member not knowing they had changed after 98. I thought all 3G DCs used the same ones.
Apr 5, 2018 11:34 AM
hyabusa hunter
Oct 3, 2010 04:19 PM
roadrunner1
19
Feb 28, 2007 07:44 PM
adrian1281
Aug 23, 2003 09:43 PM
