JDM Lower Control Arm??
I have put in my tanabe damper kit into my 93 civic ex
i did also put in the JDM LCA
I have used all the bolts from my old setup....
I tried to use that bolt where it goes into the shocks, but the old one doesn't fit the JDM LCA thread...
where can I get that kind of bolt??
thanks
thanks
oh yeah..
but.. i have installed those old bolts on to them already
I pushed them really hard
would i still be able to use those ITR LCA bolt??
thanks
thanks
uh what? Mine fit fine. They are sitting right there. Have been there for a year+. Took them out, went back to stock, went back to ITR. Still fits.
You're doin' somethin' weird.
hmm...
i don't know.. the bolt thread is probably different than the thread on the LCA
but i still managed to use the same bolt, i know it doesn't fit, but i forced the bolt into the LCA's thread
what should i do ??
what should i do ??
hmm...
what should i do ??
what should i do ??
yourself... Cross-threading or forcing stuff together or to work is not a good idea silly
If you got it in there, you should hope it stays unless you feel like buying the lca's and bolts again and reinstalling them, if thats the ONLY things you damaged...
racekar
16
Jun 21, 2004 09:07 AM
