what do i need to make my stock sway bar work with blox lcas
Old Sep 6, 2009 | 06:10 AM
border919's Avatar
Default what do i need to make my stock sway bar work with blox lcas
i have a 89 crx si.I am getting new lcas.do i need to buy any hardware to make it work or will the stock sway bar hardware work?
Old Sep 6, 2009 | 06:37 AM
redflaredcrx90's Avatar
Default Re: what do i need to make my stock sway bar work with blox lcas
if there rear you should be ok
Old Sep 6, 2009 | 08:07 AM
border919's Avatar
the stock sway bar bolts thread into the lca.do blox lcas have threads for this?
Old Sep 6, 2009 | 08:46 AM
.Manny.'s Avatar
Touching My Member
I dont even think the blox lca's have the hole in the right spot. avoid any problems and just spend a little more cash on the skunk or function7 arms if you're dead set on lower control arms. if you get shitty ones, you have to get adjustable end links. you end up spending the same or more for an inferior product.
Coopa B18c5
Feb 1, 2013 09:39 PM
Jimmy
Suspension & Brakes
Nov 26, 2010 03:09 AM
Suspension & Brakes
Feb 6, 2008 03:09 PM
go2sleep
Suspension & Brakes
Jul 8, 2006 08:47 PM
SweetChin
Apr 15, 2005 09:28 AM
