Eg hatchback sideskirt removal. Help
Well as the title says I really just want to get these things off. I took the bottom bolts out and it feels loose but it doesn't come out.
i took mine off a couple of months ago all you have to do is remove mud gards and the screws from under the car ,then from the back of the side skirt push forward and they should come right off.the only part I dont remember for sure is if you push from the back or the front either way push one way if thats not the way then push the other .You will need to push with some force.
You push to the front, And the easiest way to get the side skirt back on is to remove all the clips from the car and put them on the side skirt first. cause tryin to line them all up and push towards the back of the car is near impossible
Remove the door panel and there is clips on the inside of the skin and at the very end there is a small nut below the latch on the door that holds a clip on, then slide it foward once all the clips on the inside of the door are off.
avstar26
Apr 22, 2009 10:28 AM
