best 4th gen camber kit
Old Aug 26, 2002 | 11:31 PM
gringo7718's Avatar
Default best 4th gen camber kit
hi i am riding on coilovers and adjustable kyb shocks. i would like a very sturdy kit for as little as possible. i read somewhere that some 4-gen camber kits have problems with their front fender clearances. is that true?
i recently saw this company selling kits on ebay (spcperformance.com) and their kits are adjustable ball joints on the upper cont. arm instead of the traditional two bolts in the "hinges" of the arm. does this system work better/ easier to install?
please reccomend the best kit for front only. thanks!
Old Aug 27, 2002 | 09:52 AM
93acclude's Avatar
Default Re: best 4th gen camber kit (gringo7718)
I think that any kit you put on is going to have problems with clearance, if you adjust it to far out. If you look under the fender you can see that there is not much clearance even if everything is stock. I have never heard of the ball joint kit so I cannot tell you anything about it. I do have an Ingalls camber kit on my 4th gen and it works well. Mine is set at 1.25 deg out and has never made any noise. I have been told that adjusting past 2 deg will cause problems
Kwalsh24
Aug 20, 2006 02:12 PM
4DRPIMPIN
May 6, 2005 12:09 PM
knightlude
Apr 5, 2003 08:54 AM
