launching a turbo car.... how to???
Old Sep 5, 2009 | 02:19 AM
r1inh20's Avatar
Icon2 launching a turbo car.... how to???
So i just picked up a civic hatch that dyno'd just shy of 500 hp and i'm really having a tough time getting any traction with street tires of course, preventing me from breaking anything yet.
I plan on hitting the drag strip this weekend with a set of rims with hoosier slicks mounted. I've heard from several people that the way to launch my car is with the e brake pulled, clutch slightly engaged (pre-loading the front to not snap the axle) with the rpms around 7500... pulling through 1st expecting no traction and hopefully hooking up in 2nd
I'm sure many of you have played this game, what have you found works best for getting a decent 0-60 and not snapping axles????
Old Sep 5, 2009 | 05:55 AM
blackeg's Avatar
Default Re: launching a turbo car.... how to???
this should probably be in the drag racing forum..
you're right about the preloading. when your staging, as soon as the top lights are lit, pull the ebrake up and kinda slip the clutch a lil to drag the car up to light up the bottom lights. on the last yellow light drop the ebrake and go.
tire pressure and launch rpm is a lil bit of work to find out, pretty much only done by trial and error seeing what the car likes. how big are the slicks? do you have more than 1 stage boost? they all are factors. start with the tires at like 9ish psi and maybe launching in the mid 6000s. see if its bogging or spinning and go from there.
make sure to get a good burnout. pull into the water box, put the car in 2nd gear and pull the ebrake up hard. when the starter signals, bring the revs up, drop out the clutch and heat them tires up for a few s econds.
Old Sep 5, 2009 | 08:12 AM
boostedcivicsir's Avatar
Mr. Badwrench
you have to play with tire pressure and launch rpm.
moving to drag. youll get better responses in there.
Old Sep 5, 2009 | 06:12 PM
r1inh20's Avatar
2nd gear burnout in the waterbox??? can i ask why? this e-brake thing is either gonna go really well or really bad LOL
Old Sep 5, 2009 | 06:53 PM
jnv255's Avatar
its not as hard as you think, pull ur ebrake up, slip your clutch so it pulls you into the staging beams. when your staged push the clutch in far enough so its not pulling you forward.
Old Sep 5, 2009 | 07:33 PM
r1inh20's Avatar
i think that will just take some practice.... can anyone tell my why the 2nd gear burnout in the water box??? i haven't tried smoking the tires in 2nd, yet.... but it will smoke the tires in 4th on the hwy so i assume it won't be an issue
Old Sep 5, 2009 | 07:35 PM
PRO1's Avatar
WTFO and dump the clutch
Old Sep 5, 2009 | 08:18 PM
r1inh20's Avatar
haha sounds good.... i'll do it but only because i'm in the water otherwise i am 100% certain the axle would snap like a toothpick, but why 2nd and not 1st gear????
Old Sep 5, 2009 | 09:17 PM
mozzandherb's Avatar
Honda-Tech Titanium Member
yeah preloading definitely gets some getting used to, but it really is finding the right tire pressure and launch rpm's...and I'm not certain, but I think a 2nd gear burnout just allows you more time to spin the tires before you hit your rev limiter, more lag I guess, but like I said I could be very wrong.
Old Sep 5, 2009 | 09:40 PM
r1inh20's Avatar
i am set up with a 2 stage launch control it's set at 7500rpms... that makes sense mozz cuz in 1st gear it'd cut out unless i just kept blipping the throttle off and on, hopefully i won't kill it or brake my e-brake LOL
Old Sep 5, 2009 | 09:45 PM
7500rpms...wow that is pretty high
Old Sep 5, 2009 | 10:46 PM
fukenricen's Avatar
with mine what i do and im still getting things setup so i guess the pros can correct me.
1.get to the burnout box spin once in water.
2.go a little past the water section and jack the ebrake up,put it in 3rd gear,i stay on the 2step and build boost then get off the clutch and hold down the gas all the way and the car will drag you with the ebrake once it starts hooking.
3. get to the light rev to the rpm you wanna launch it (hold down gas all the way if your on a launch control system) hold ebrake up , let go of the clutch slowly and ebrake till you hit the first beam, then do it till you hit the second beam(letting the car creep to the light).
4.once in the beam hold that ebrake up and hold gas at rpm you want and clutch a little up till the car almost wants to move but it wont and when the green light comes, release ebrake and clutch.
hope that helps
Old Sep 5, 2009 | 10:58 PM
gringotegra's Avatar
You bought tim from revv's old car right??
Old Sep 5, 2009 | 11:00 PM
r1inh20's Avatar
hope that helps
you are the man
r1inh20's Avatar
yes miles, and no you cannot have my motor LOL
Old Sep 5, 2009 | 11:01 PM
r1inh20's Avatar
that's what i though, motor is good for 10k but rev limiter is set for 9k
Old Sep 5, 2009 | 11:08 PM
fukenricen's Avatar
i have mine at 6700on the hondata
Old Sep 5, 2009 | 11:12 PM
Nah im good dont want your motor ..
Im pretty sure you can lower the launch on the car... mine is set at 7000rpm and i make 80ft/lbs less than you and still have 10psi off the 2step at that rpm... thats probably why tim could never cut a 60ft in that car he never worked with the launch with it... and i have the same exact setup as that car so i know what it does...
Old Sep 5, 2009 | 11:13 PM
r1inh20's Avatar
yeah i think mine could be turned down a bit, tim ran a 10.8 in the car but i have absolutely 0 experience with a fwd turbo car, i'm a big fan of rwd and awd cars but this car was too fast and too cheap to pass up and he built the motor RIGHT, i'm pretty excited to get it figured out and run some 11's
Old Sep 5, 2009 | 11:14 PM
fukenricen's Avatar
takes time thats all , what system are you using on the car ? like hondata?
Old Sep 5, 2009 | 11:15 PM
r1inh20's Avatar
tim said you were running a basically stock gsr block that isn't sleeved.... maybe you are sandbagging everyone??? LOL
Old Sep 5, 2009 | 11:22 PM
I meant the turbo setup..its the exact same turbo kit... tim made 482/388tq... i made 444whp/312tq... and yeah stock motor for me and a heavier car
if you need a driver to help you with the car im local and have lots of experence
Old Sep 5, 2009 | 11:35 PM
r1inh20's Avatar
i de-tuned to 15 psi for the street and switched it back to pump gas for 419 whp last week, i'll hit the track once in a while but it'll be on the road most of the time... i didn't realize how hard it is to get traction with a fwd car, i've had a ton of fast cars and bikes but i have to give all you guys credit... it takes more effort and skill to make these cars get traction and go fast, especially from a dig and i've driven almost everything
Old Sep 5, 2009 | 11:39 PM
Yeah theres some skill in them indeed...
Old Sep 6, 2009 | 09:28 AM
0554's Avatar
myle's knows about skill haha
