99 Teg, Suspension Question
Old Sep 5, 2009 | 01:08 AM
I Still Love H.E.R.'s Avatar
Default 99 Teg, Suspension Question
I have my mind set on some Function Form Type 1's, and is wondering where the cheapest site or place is to get them...
Old Sep 5, 2009 | 01:16 AM
racebum's Avatar
Default Re: 99 Teg, Suspension Question
why o why would you ever want a set of those?
pic? koni/gc? skunk pro-c?
any of the above look attractive? they should.
FF like most of the other south china sea junk shocks have untested dampening curves, blow out and are hard or impossible to service. we've went over this many times in the suspension forum. it's your money but FF is one place i wouldn't spend my $500
ever notice most of the guys who autocross at PIR including myself are on koni/gc?
Old Sep 5, 2009 | 05:03 AM
DC2uNer's Avatar
check vendor marketplace.
Old Sep 5, 2009 | 06:58 AM
95 integra's Avatar
I have the F2 Type 1s and I hate them. Made for ricers who want to slam their car to the ground (which makes them popular around these parts). Dampening blows, still havent decided whether the spring rates blow as I need to check my preload, but out of the box the rears are stiff as **** and the fronts are soft and bouncy (either shitty dampening or too little preload...or both). I have the rears jacked up as high as they will go and I barely have room between by fender and tire (which I wanted about an inch and I have about a quarter).
Basically if you want to slam your car to where its tucking wheel (not tire, but wheel) and have complete **** spring rates/dampening, then go for them. Otherwise, but something worth a ****. Possibly the Type 2s are better, but the hell if I'll buy them to find out.
Old Sep 5, 2009 | 09:04 AM
I was checking out the Koni/GC set ups but i was a bit confused, with the spring rates and all that...What would be the best koni/gc set up for a daily driven car that might get autox when the times right? I am also looking for the best bang for the buck because the koni/gc setup is like 8-900 with top hats...Thanks for the help guys
Old Sep 5, 2009 | 11:00 AM
racebum's Avatar
unless you're going below flush you don't need tophats. if you do get them, the front is the most important since it sits lower than the rear and tends to compress the most. rate wise for dual purpose. well, it depends on the tire you run
1. kumho xs, star spec and others under 200 treadwear. use springs 500/450
2. yoke s drive, pozenza 760 and other harder sport tires 300 treadwear or under use springs 450/ 400
3. all season tires that are hard as rocks, above 300 treadwear like the kumho ast. use springs 400/350
these rates will give you a sporty feel and let you keep in touch with what the suspension is doing. going to stiff on too hard of a tire basically makes your car feel numb since it becomes harder to feel the limit.
Old Sep 5, 2009 | 11:39 AM
okay, so what if i want a spring rate that i can use with all the different set ups? If i order the GC's from the marketplace should i tell the seller the spring rates i want are (ex. 450/400) or are there GC coilovers that i could just use without having customized spring rates? I want to be able to go pretty low yet still have the functionality
Old Sep 5, 2009 | 01:55 PM
racebum's Avatar
they are all the same. if you order without saying they just choose rates for you and send 380/250. going 450/400 {this is basically 8k-7k in jdm talk} would allow you to get pretty low, not scrape and at the same time, not be so stiff that your car is numb. i would order your koni gc through thmotorsports and tell them the rates you want. the whole combo is 799 shipped or 919 with front top hats
Old Sep 5, 2009 | 04:42 PM
okay so how low will the 380/250 spring rates get me? Allow me to tuck? I've been reading around and noticed that 450/400 was pretty popular...sorry for asking so many questions i'm just new to this whole spring rates stuff. This is also my first time buying suspension, so i figured i'd do it right the first time.
Old Sep 5, 2009 | 09:41 PM
95 integra's Avatar
Allow me to tuck?
Thats all I needed to know....just go w/ the F2 Type 1s.
Old Sep 5, 2009 | 10:50 PM
I've heard the koni/gc set up will go pretty low... any truth to this
hondateg08
Suspension & Brakes
17
Dec 26, 2008 05:22 PM
lsegcoupe
Suspension & Brakes
Jun 28, 2006 02:21 AM
tatted91rex
Feb 8, 2006 09:53 AM
acurasquirrel
13
Oct 15, 2003 06:53 PM
nfiedler3
Jan 6, 2003 09:16 AM
