ef9 ac brackett?
hi, i got a stock 91 civic si and i'm gonna put a gsr motor in it and i want to keep the ac. Will the d series ac bracket fit on a b series block or if not, will the d series compressor fit with an b series ac bracket?
you obviously didnt do any research. if you had you would have come to this answer:
you need to use an a/c adapter bracket on a b-series motor or possibly an a/c bracket out of a b16 crx/hb. and aslong as you have a sanden model compressor and a/c lines then the adapter bracket will work.
slowpokesi
17
Jul 20, 2002 08:31 AM
