Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
need k series help!!!
Old Sep 4, 2009 | 03:31 PM
DennMann89's Avatar
Default need k series help!!!
ok so i know this is asked many times and its probably in the FAQs so dont jump down my throat for asking but i need help just with wiring my k series up.
ive got the ecu wired up. that was easy but to by-pass the immobilizer...thats the problem.
ive read the forum many time thru the k swap section and just dnt get it and dnt wanna waste 250 dollars on the damn box thru hybrid to bypass it.
so my question is can anyone give me pointers or help on bypassing the immobilizer?
how do i go about wiring that?
thank you
Old Sep 4, 2009 | 05:06 PM
hnycrk's Avatar
Default Re: need k series help!!!
if you have k-pro you can disable the immobilizer that way.
p.s. a lot of k-swap info here..... www.k20a.org way more than you'll ever find here...
Old Sep 5, 2009 | 09:35 PM
DennMann89's Avatar
yes i know about k pro but that really isnt an option rt now...but ill check out tht forum too...i am a member of that also
Old Sep 5, 2009 | 09:56 PM
j_moreno's Avatar
If you are useing a usdm k call your local acura or honda dealer and see if they would be kind enough to reprogram your key code to the ecu. u'll need the vin from the ecu and your cars. CALL and find OUT FIRST SO YOU DONT PAY FOR A TOW FOR NO REASON.
skaterdude04
11
Feb 24, 2009 07:12 AM
bllkhatch
11
Jan 29, 2007 05:21 PM
evilsolb16
May 22, 2005 12:42 PM
Bizzar
Sep 17, 2003 10:49 PM
