Tach and Speedometer dont work
Old Sep 4, 2009 | 11:02 AM
B18CTYPER2000's Avatar
Icon6 Tach and Speedometer dont work
Does anyone know how to fix a tachometer and speedometer that do not work? My gas and temperature gauge work but my tach and speed dont.
Does any one have any ideas?
Old Sep 4, 2009 | 11:03 AM
solo227's Avatar
Default Re: Tach and Speedometer dont work
check your speed sensor...
Old Sep 4, 2009 | 11:36 AM
Former User's Avatar
Is the CEL on? What year?
Most Civics get the tach signal on the blue wire from the igniter unit/ICM in the distributor but, for 99-00, the blue wire tach signal comes from the ECU. Check the blue wire for continuity and bad terminals in connectors.
The speed signal comes from the VSS (speed sensor) that sits atop the transmission. Check the power wire and ground wire, and continuity of the third wire that runs to the cluster. If the sensor is fine, another common problem appears to be a bad VSS connector.
Old Sep 8, 2009 | 06:23 AM
There is no CEL on and the car is a 2000 honda civic si Body with a EX motor. (long story)
Old Sep 8, 2009 | 06:44 AM
Jimster480's Avatar
What year EX Motor? Because the Si is OBD2B.
civic08
Feb 28, 2008 09:22 PM
GsrTurboCRX88
Mar 20, 2006 03:18 PM
splinter51
10
May 5, 2004 04:40 PM
team2n1hatch
Jun 18, 2003 09:37 AM
