B18c1 Complete
I've got a 1995 B18C1 LS motor COMPLETE. Comes with alt,ac
125xxx on the motor when pulled.. the car was rear ended and written off!!....
Pulled strong didn't burn ANY oil,
Valve lash adjustment,Timing belt!, water pump, VC gasket. All just replaced
Motor is clean all you need is a tranny and a starter and you got everything..
I can include the ecu and a set of axels but that will be 50$ extra.
ENGINE COMES WITH FULL WIRING HARNESS ATTACHED!
Looking to get 700CND. OBO
SHIPPING NOT INCLUDED!
hmmm, if it doesn't say VTEC on the valvecover then you have an LS engine.
But if the code on the engine block says b18c1, then it's a gsr engine. Unless someone put an LS head on a GSR block which makes absolutely no sense.
Figure out which one you have. If it's a GSR engine, it's worth more than 700, if it's an LS engine then this is decently priced.
