Gauge pod top mount or cluster mount?
Old Sep 4, 2009 | 06:48 AM
xXB18EKHatchXx's Avatar
Default Gauge pod top mount or cluster mount?
Anyone running the replacement cluster dual gauge pod or a top-mount frog eye style pod? I was wondering which you felt was better due to visibility issues, preference, ease of install, etc. Looking to add an oil pressure and water temp gauge set and not sure which one puts the gauges in the most advantageous placement.
Old Sep 4, 2009 | 07:09 AM
rick_rabies's Avatar
I'm not Rick!
Default Re: Gauge pod top mount or cluster mount?
say NO to pillar gauges. get a climate or radio din and put holes in that...youl thank me
Old Sep 4, 2009 | 07:17 AM
Not talking pillar mount, talking about the style that sit on top of the actual speedo hump on the dash or the style that replaces the black plastic trim in front of the actual speedo cluster. I thought about the blank panel where the radio used to be but that isn't in line of sight.
edit: Just got me thinking, top mount will still be too obvious that something is there which is why I hate pillar mounts. Thanks Rick!
Last edited by xXB18EKHatchXx; Sep 4, 2009 at 07:20 AM. Reason: not enough coffee to spell properly.
Old Sep 4, 2009 | 07:34 AM
I'm not Rick!
if you have a small steering wheel the top mount dealy is hard to see.
the gauge cluster ones block the original temp and your fuel guage. but you are installing another temp gauge anyways. anyways cheers. im sure it will be clean either way
Old Sep 12, 2009 | 07:38 PM
808Army's Avatar
Do any one know where can get climate or radio din? for 96-00 civic thanks
the rook
Sep 22, 2015 03:04 PM
Casp3r88
Jun 21, 2009 07:17 AM
EngineNoO9
Honda Motorcycles
24
Nov 23, 2005 03:30 AM
fastsohc
Apr 15, 2005 04:53 AM
YodaIsGod
Apr 2, 2002 07:09 AM
