95 Integra ABS delete question
Old Sep 4, 2009 | 05:24 AM
matt94z's Avatar
Default 95 Integra ABS delete question
Im getting ready to delete the ABS, because its ugly, in the way, and theres possibly something wrong with the unit.
My question is can I use a booster and master from a 4dr EG or a DA? The reason Im asking is because I have those parts lying around. Any info is appreciated!
-Matt
Old Sep 15, 2009 | 05:52 PM
53JDMDC2's Avatar
Default Re: 95 Integra ABS delete question
i just deleted abs from a 95 teg. all i did was get proportioning valve from a 98 non abs and hooked the lines up and everything works great.
stupidly i havent blead the brake yet. works great.
u can make it look stock more than the one i did. all you really need is a proportioning valve from a non abs car. it has to have 6 line connections.
Old Sep 15, 2009 | 10:18 PM
gtrtttopher's Avatar
New User
you're booster and master will work you don't need to swap thos over. u might have to make a line and get a 40/40 proportioning valve, ive read about it b4 that there's a rs integra line you can order so u would just need a the prop valve. wish i knew the part number.
Old Sep 15, 2009 | 10:20 PM
New User
did you use a duck foot prop valve? is that what you mean but 98?
trm4life
Apr 27, 2017 05:28 AM
ZCHondaCRX91
Suspension & Brakes
Feb 4, 2012 09:18 PM
HmgLauj69
Sep 22, 2011 02:57 PM
Mattcuzko
May 15, 2011 09:54 PM
