ITB's with air filter?
Old Sep 3, 2009 | 03:34 PM
8OOSTED's Avatar
Default ITB's with air filter?
ITB's aren't very streetable because of the whole no air filter thing so has anyone ever rigged a filter on one of these before?
Old Sep 3, 2009 | 04:51 PM
Mistergou's Avatar
Default Re: ITB's with air filter?
Im sure you can make a filter box setup for them..
but IMO filters on ITBs are pointless... to much power loss..
just change your oil more frequent an you will be fine
Old Sep 3, 2009 | 05:29 PM
beansandrice's Avatar
BAM!
Old Sep 3, 2009 | 05:31 PM
Double bam!
intecracing.com
Old Sep 3, 2009 | 05:36 PM
8OOSTED's Avatar
Originally Posted by beansandrice
BAM!
Perfect! Thank you.
Old Sep 3, 2009 | 06:40 PM
Top Ramen's Avatar
How much of a loss did you measure?
Old Sep 3, 2009 | 07:16 PM
GhostAccord's Avatar
I'd like to see the documented power loss as well.
If you get a set of the K&N individual filters. There is a set with velocity stacks integrated into them. You probably wouldn't even notice a power drop, maybe even a gain, depending on your setup.
If this is a daily driver, I would suggest against running it filter less. Running without a can end up doing more harm than dirtying your oil faster.
Old Sep 3, 2009 | 07:18 PM
cody2689's Avatar
ha thats pretty badass....i wonder if you would have problems fitting behind the firewall
Old Sep 3, 2009 | 07:24 PM
Here is my test fit without filters.
These are a set of 14" ITBs and I have fitted a 5" air filter box on them and still had 1" of clearance. If your running TWM or any other sort runner ITBs. I would imagine that you should have more than enough of room for a set of 4" filters.
Old Sep 4, 2009 | 05:33 AM
92TypeR's Avatar
FSAE
I think a better idea than having four individual filter elements on each runner would be to fabricate an airbox and feed a cold-air duct, and run a standard K&N cone filter at the end.
Having a filter at the end of your runner reduces the velocity of the air entering, as it blocks any flow in the 90* to 180* range, assuming you have 180* velocity stacks.
Old Sep 4, 2009 | 06:37 PM
Yes and you are 100% right but for just farting around town with the ability of removing when you get to the track (cough, street, cough, cough,) Filters are great and cost alot less then that beutiful carbon fiber piece.
Probably sound more beastly.
Old Sep 4, 2009 | 06:38 PM
By far a big no, no. Not just dirty oil but messed up rings scratched walls etc...
Old Sep 4, 2009 | 08:00 PM
projectTeG's Avatar
pipercross filters, jenvey.
talk to donf.
Old Sep 4, 2009 | 08:18 PM
Timmah!!'s Avatar
http://www.itgairfilters.com/index.asp
We use them on our carbed datsuns...
Old Sep 5, 2009 | 09:05 AM
stl eh2's Avatar
true choice has kits aswell
Old Sep 5, 2009 | 09:12 AM
killerpenguin21's Avatar
LULZ
you should do some research before you talk
Old Sep 9, 2009 | 02:05 AM
8OOSTED's Avatar
Clean your engine bay! lol jk.
Looks sweeet!
Old Sep 9, 2009 | 02:16 AM
Thanks
Yeah I know...pretty dirty eh!
Hows this for clean
Old Sep 9, 2009 | 02:22 AM
im a monster hehe's Avatar
put panty hose over them and tripple rubberband
Old Sep 9, 2009 | 02:01 PM
8OOSTED's Avatar
Thanks
Hows this for clean
Holy **** you motor looks good! Let's see it dropped in.
Old Sep 9, 2009 | 02:36 PM
Stay tuned for that on my build thread/blog. Nether the chassis or the engine are finished just yet. I kind of hit an unemployment, now back in school, speed bump. Should be back on track in a few months.
Old Sep 9, 2009 | 03:57 PM
D.Jones's Avatar
We used quad filters on a B18c eg hatch.
Old Sep 9, 2009 | 04:51 PM
patriot's Avatar
Why is your alternator pulley so damn big?
Old Sep 9, 2009 | 04:58 PM
JDogg's Avatar
we ran some foam filters made to go on itb's .. forgot the brand.. lost about 15hp
Old Sep 9, 2009 | 07:20 PM
iskate2's Avatar
thats not why theyre not that streetable- you ever dealt with daily driving itb's?
looks like the airbox was the best idea- hot air from the header moves underneath the engine and falls up into the low pressure area behind the motor where the intake is. plumb it outside and id bet youd see a nice improvement in power from change in air temp alone.
