gsr with itr pistons
Old Sep 3, 2009 | 03:09 PM
1_sick_si's Avatar
Default gsr with itr pistons
ok im trying to find out if im going to have any problems putting itr pistons in a stock gsr block with the gsr head? I also wanted to know around what hp numbers i would be looking at if i put a skunk2 pro series intake and a set of dc headers/
Old Sep 3, 2009 | 03:29 PM
88Hatchy's Avatar
Default Re: gsr with itr pistons
no problems with the GSR head. You will make 8.7 horsepower.
Old Sep 3, 2009 | 03:40 PM
OH_1fstgsr's Avatar
I have a GSR with USDM ITR pistons in it. Also have the DC Sport 4-1 for now. I have a ported GSR intake manifold. This should give you some idea.
Tuned with a Hondata S300 I made 182/134 on a dynojet.
Old Sep 3, 2009 | 07:42 PM
1_sick_si's Avatar
Thanks man
Old Oct 18, 2009 | 02:41 AM
OXY95LSSC's Avatar
I have the same question. so is this setup able to run on a stock ecu? plug and play? or is a tune needed...? any smog issues? (i live in California)
I got a 94 gsr & my bottom went out. I want to swap in a stock gsr block with itr pistons. let me know all that is needed to do so.
Old Oct 18, 2009 | 04:28 AM
QUICK8CIVIC's Avatar
Yes you can..
Old Oct 18, 2009 | 04:29 PM
thundernoodle's Avatar
you should be fine w/itr pistons. 1pt in comp. isnt much but to see the most youll have to tune it.
What are you all running your GSR's up to on the dyno?
wreckeddc4
Aug 20, 2007 09:30 AM
gsrboost
10
Oct 2, 2005 07:46 PM
SPOON 1
Jul 26, 2003 08:57 PM
super laubo
Mar 13, 2003 01:35 AM
vtec8k
Feb 15, 2002 11:32 AM
