motor "dies" at 2000rpm
Old Sep 3, 2009 | 02:08 PM
mother ef-er's Avatar
Default motor "dies" at 2000rpm
i have a 90 civic with a stock lower end, and a z6 head swap. everything converted to obd1, the car runs great.
this problem happens more often than not.. i will slowly come off the clutch in first and simultaniously slowly give the car gas. now the motor runs beautiful up until 2000 rpms. it seems like as soon as i hit 2000rpm, the motor drops to maybe 400rpm, almost like the motor is "shutting down" but just for a second or two. then if i keep my foot off the clutch and my other foot steady on the thottle while this is happening, the motor "re engages" and the car jumps really f****** hard and continues accelerating from 2000 rpms. no problems accelerating at all after this "jump" happens.
so to keep from this happening on the road, i need to get the car to about 3000 rpms before coming off the clutch to launch. this poblem happens in all gears including reverse. and the problem was really bad before i did the head swap. but iv had two different transmissions in the car. it also does this while i have the car in neutral. so i am sure its a motor issue.
Old Sep 3, 2009 | 04:03 PM
Default Re: motor "dies" at 2000rpm
bump for the saints game.
Old Sep 3, 2009 | 04:06 PM
r b k a's Avatar
bump.
a lot of people are having power loss problems including me :/
Old Sep 3, 2009 | 06:33 PM
when i had the original head on the car, i was under the impression i may have had a stuck valve... thats one reason i did the head swap. the motor is so much more responsive now and im a little further from the "jump" problem iv been having, but the problem is still a big issue.
** iv tested vacuum lines briefly, no leaks!! im going to further test vacuums tomorrow, but im sure thats not my problem.
Boosted97dx
Jul 9, 2013 02:21 PM
BubbleSnail
Sep 21, 2010 09:44 PM
ComptonsF1NEST
Jun 13, 2006 07:37 PM
neXus dc4
May 4, 2004 06:32 PM
iH8RICERZ
Feb 4, 2004 05:21 AM
