B18B OBD2 Valve Cover OBD1 Engine
Old Sep 3, 2009 | 12:24 PM
candyman206's Avatar
Default B18B OBD2 Valve Cover OBD1 Engine
I got an OBD1 engine and just picked up the OBD2 valve cover because it looks better. Dont know what to do with the PCV hole on the valve cover so I decide to use it. Only problem is the OBD1 PCV is connected inline with the vacuum port on the intake manifold to the black box on the back of the engine. My idea was to get the OBD2 PCV and put it in the valve cover and run the vacuum tube from the intake manifold to it, and just plug up the hold on the black box. Will this cause any problems plugging up the black box and running the PCV this way? What will be the best way to do it?
Old Sep 3, 2009 | 01:39 PM
pmey's Avatar
Default Re: B18B OBD2 Valve Cover OBD1 Engine
just plug the hole on the the obd2 valve cover and the your original pcv alone.
meyerk9
Nov 10, 2010 02:32 PM
candyman206
Sep 3, 2009 09:11 AM
jdmdc2boi12
Apr 9, 2009 08:46 PM
chevellion
Nov 3, 2008 08:46 AM
povs9
Feb 26, 2007 07:52 PM
