TW Parting Out my 2000 Honda Civic DX Turbo! 327WHP SOHC BUILT MOTOR PARTS! CA
Old Sep 3, 2009 | 09:20 AM
Quad-Damage's Avatar
Default TW Parting Out my 2000 Honda Civic DX Turbo! 327WHP SOHC BUILT MOTOR PARTS! CA
This is just a Testing waters, I wanted to sell the car whole, but I'm not getting any good offers, just some tire kickers and high school kids. I'm about to part the whole car.
I am willing to ship everything, if you are willing to pay for shipping. I have Pay pal, but i would prefer MO. I am legit look at my join date and tons of vouches under my name.
Full D16Y8 Block (REDZONE BUILT) BLOWN HEAD GASKET 850 Completed Block
Darton Sleaves 75mm .20 over 1.6 LITER (Cost me 600 here alone)
Bored, Honed, Decked
Blanced and Blueprinted Block
Wesico Pistons -w- rings, with the coated skirts
Eagle 900HP H Beams Connecting Rods
Crank balanced, polished
OEM HONDA! Bearings
New Oil Pump (Honda) Shimmed for high flow
New Water Pump (Honda)
New Alternator Honda)
NEW OEM HONDA Heat shield Gasket Intake)
OEM Honda Head gasket !blown!
Head BUY COMPLETE! 655
Full D16y8 Head (CLEANED)
9.0.1 comp overall
Redzone P&P 3 angel job both sides, intake and exhaust (SUPER NICE) 230
D16y8 ARP Head Studs TOruqed to Spec 55
ZEX Honda D16Y8 - Stage 1 Street/Strip Performance Cam 180
Ferrea Racing 6000 Series Competition Valves .5 Oversized (YES 6000 SERIES) 155
Ferrea Racing valve springs 120
Ferrea Racing Components Titanium Retainers 120
Would love to sell the motor complete, it has a blown head gasket but was very strong before and ran fast and never had a problem with it.
Tyranny
Rebuild RedZone D16z6 5 Speed (small grind going into 3d when powershifting fixed with syromesh, strong tranny, LSD grips hard!) 525 comes with OBX LSD INSTALLED with new washer and torqued to spec
RedZone Stage 3 Clutch 150
ACT XACT Street Lite Flywheel 11 pound 125
OBX LSD Beveled so i can take the axles out
ALL NEW OEM HONDA BEARING AND WASHERS Installed and Torqued to Spec
Gator Stage 2/3 Axles 400whp 275
ARP Extended studs, for mounting my monster 24.5 9 13's slicks Comes with brakes
Motor Bolt On's (Other Parts Inside of the Motor Bay)
MSD SCI 10,000RPM 125
MSD Blaster 2 Coil 30
2000 Honda Civic MSD Cap and Coil with New Inginitor Setup for MSD 40
Hondata 3 Bar Sensor 2x 45
2000 D16y8 Engine Harness, Car is All Wired for VTEC (WIRED TUCKED) 55
2000 Honda Civic D16y8 CUSTOM Sheet METEL Intake Manifold 85
2001 Integra Type R Throttel Body 64mm 105
AEM Tru-Time Adjustable Cam Gears (Silver) COVERED 55
AEM Tru-Power Pulleys (Red) 55
AEM High Performance Fuel Filter (Red) 45
AEM Fuel Rail (Red) 45
AEM Fuel Prssure Reuglator (Red) 55
Walbro 255LPH Fuel Pump 50
RC 750 sats injectors with OBD 1 Clips 230
Fluidyne Raditor 1/2 Size for a B Series, Custom Mounted on my D (POLISHED) 120
Greddy Oil Cooler relocation Kit 50
Greddy Oil Cooler Lines And Adapters 100 PSI UPGRADED LINES (THESE LINES cost me alot of BANK) 35
Runs near batter to oil cooler in front.
B&M Oil cooler 55
Greddy Water Temp Kit 15
Custom QuadWarez Ground Hyper Wires 10
NGK Spark Plug Wires 35
NGk Stage 3 Colder Plugs Gaped .28 10
Black Honda OEM Valve Cover with breather 3 in 2 out 50
Password JDM Magnetic Oil Drain Plug (Honda) D16y8 9
Turbo Setup
Spoolin Performace Turbular D Series Manfoild 420
Precision T3/T4 Street & High Performance SC-3427E .57 Trin *JET Coated Housing* 455
Tail Wastegate 10 PSI 38mm 130
Fake *JET Coated* Tail BOV 50mm 85
Spoolin Performace 2.5 inch to 3 inch DMH E-cutout **JET Coated** 125
Spoolin Performace Oil Feed Lines 15
Spoolin Performace Oil Return Lines 15
Spoolin Performace Dumptube *JET Coated* 20
JRC 8 Inch Intercooler *JET Coated* 90
Suspension
Brembo Front Cross Drilled Rotor System 80
PBR Ultimate Ceramic brake pads *GREAT PADS* 30
99-00 Civic JDM Civic Type R E brake cables 50
01 Acura Integra GSR Rear Disk Brakes 100
01 Acura Integra GSR Rear Disk AEM Brake Pads (Pads have 5000 miles on em)
Omni Power Full Coilovers with upgraded collers for 700whp 450
Omni Power Front Camber Kit 65
Omni Power Rear adjustable camber links, 2 inches in back and 2.2 in front (NOT WASHERS) 55
Suspension Techniques Speedtech Sway Bar System 160
Back Strut Polished Bar 15
Custom Quadwarez High Temp Gunmetel Painted Claipers EX
Custom Quadwarez High Temp Gunmetel Painted Claipers GSR
Zenki Red Extended Lug Nuts 16 4 x 4 15
ARP Extended Studs for Mounting Slicks
Gator Stage 2/3 Axles 400whp +
Full Race Gold Polished Traction Bar 200
Polished Hasport Race Mounts 70mm (RACING MOUNTS) Drive Side, Tranny, Rear Engine Mount, Shifter Mounts 250 for all mounts
Buddy Club P II New Tires 225 15 inch Drag Radails G-force's on the Fronts %65 + left
and Dunlop Durizoes in the Rear 205 %75 left maby 400 miles on them 500 for rims and tires
Exhaust
2.5 inch custom piping. Tig Welded to a Carbon Fiber Muffler 270, DIRECT FIT for any EK
Car's Inside
2000 Honda Civic Black Si Dash,(Black in color) and FULL Interior (COMPLETE SWAP WITH THE CARS LEGIT VIN) + WITH BLUED TAG! by CHP ALL LEGIT! 150
Custom Fited, with JDM ARM Rest and custom gauges all black, SUPER SICK INSIDE! + Cutout cookpit button for cutout
2000 Honda Civic Si Climate Control Unit (FULL SI INSIDE, Moon, Sun, Power Roof ALL)
Omni Power Custom detachable hub Quick Relase 50
Momo Srerring Wheel Hub 50
Momo Steering Wheel with Bride Logo 30
Bride ERGO II Black FA [E11ATS] Seats 2 (YES BOTH) in BLACK with Custom Bride Rails Fake Seat, 1 is needs new pading and starting to fade, custom ek rails 380 for both.
1 F1 Spec Black Seat, with Rails for EK 230
Civic 2 Pod Gugue Holder On Cluster 30
Defi D-Gauges 52mm 0-35 psi Boost Gauge 40
Nordskog performance LED Digital Fuel Pressure 0 - 100 psi-RED Display 35
Fuel Pressure Sending Unit Kit 10
Summit Digital Gauges 2 1/16 in. diameter, black face, red LED display, voltmeter, water temperature, and oil pressure gauge, digital gauge panel kit 50
Summit Racing Senders For Voltmete,water temp, and oil pressure (Only have the volt meter, I broke the water and oil temps, u can reorder them from summit)
FD Xtreme Bulb 100/130W Platinum White 10
Black JDM Headlights 80
Si Gauge Cluster 30k MILES! 100
OEM 00 Si Shift Boot 5
2001 GSR OEM Shifter 15
Skunk 2 Shift *** 15
Power Door Locks All 4 Doors
NO CD Player, GOT STOLEN!
MB Quarts DKC 169 6.5 in Rear 2x 40
MB Quarts DKD 113 5.25 in Front 2x 40
VIPER 791VX with 2 NEW REMOTES
With Backup Battery 300
Clifford GS 200 with Blackjax option 300 (U can keep the car after getting car jacked)
Cars Mods on the Outside
Repainted in 2004 Custom GUNMETEL COLOR, SMOKED GRAY
Black JDM Headlights Home Made 75
99-00 Crabon Creation Carbon Fiber Front Grill 90 Starting to Oxidize
Sumit Racing Hood Locks
Carbon Fiber Hood Oxidized 150
Carbon Fiber Mugen Front Lip 140
Lower'd 2.5 inchs
ECU and TUning
Obd 2B to OBD 1 Conversion Harness *Bloomslang*
OBD 1 IAC Sensor 10
p28 Chiped with CROME PRO STREET TUNED AND DYNO TUNED BY JEARMY and BRANDON from Redzone Performance 150
P28 Redzone Chiped and Tuned Crome PRO $7880 in parts alone I'm asking
321whp and 228tq @ 14 psi. RUNS ON 91 PUMP GAS!
The car has over $9000 in parting alone! or 6000 for the car complete, 2 bad people didn't see that. Good investment if you want to buy it outright.
The SHELL HAS LOW LOW LOW MILES. 32XXX MILE and CLEAN TITLE! Never been in a crash, CLEAN CAR FAX! None Smoker, a few dings and ok paint, but a very Nice 2000 Honda Civic DX SHEEL! It's the last year the EK's were made + it's a cool 4 door thats different.
Shell for $3000 none rolling
Shell for $4000 rolling Comes with onmi's and breaks and stealies No motor or inside, seats ect, will put on stock wheel. missing parts of the dash
I want to get interest 1st and go from there. I would be more then happy to do package deals! The more you buy the more I am willing to work with you.
PM IF you want to do a package deal, the more you buy the better deal i can make, let me know if you want everything as well, see my other add for the car for sale here.
http://www.hondamarketplace.com/show....php?t=2543297
You can also email me at
TurboCivicbayarea@yahoo.com
The Car is Located in the Bay Area, I can meet up with you in the 510 Area Code with some friends.
Old Sep 3, 2009 | 10:39 AM
Default Re: TW Parting Out my 2000 Honda Civic DX Turbo! 327WHP SOHC BUILT MOTOR PARTS! CA
This place moves fast
Bump if u like it, or bump if u pm me
Old Sep 3, 2009 | 12:22 PM
etank82's Avatar
PM'ed...
Old Sep 3, 2009 | 01:39 PM
Pm
ed back!
Old Sep 3, 2009 | 06:27 PM
vche101's Avatar
Bump
Pm'd!!!
Old Sep 3, 2009 | 10:18 PM
DaBeastWthn's Avatar
PM Me how much for all this shipped to 63368:
Skunk 2 Shift ***
Old Sep 3, 2009 | 10:45 PM
alot of people want the skunk 2, still testing if alot of people want parts it will be parted.
Old Sep 4, 2009 | 09:22 AM
Oh? Sorry...when I saw actual prices next to each part I thought you were parting it now. I guess just PM me if you are and I'll let you know if I still need anything.
Old Sep 8, 2009 | 04:23 PM
jdm_george's Avatar
bump
Trojan Man
Feb 12, 2011 05:47 PM
Trojan Man
Mid-Atlantic (Sales)
Dec 19, 2010 05:30 AM
LSVTEC426
Oct 10, 2010 10:42 PM
JDM_FRONTIN
Nov 15, 2005 08:55 AM
