Rear door/rocker rust - repair and prevention
Old Sep 3, 2009 | 04:54 AM
scoob8000's Avatar
Default Rear door/rocker rust - repair and prevention
So I'm finally tackling the rust on my 94 DX. I already took care of the wheel arches, but the rockers down by the bottom corners of the rear doors are pretty bad. The previous owner just filled them with bondo and never even painted them.
Is there a common cause for rust in this location (water/salt coming in from somewhere not obvious)?
I don't want to fix it and just have the rust back again in a few months.
Old Sep 3, 2009 | 07:35 AM
teal_dx's Avatar
Default Re: Rear door/rocker rust - repair and prevention
the water would run down and sit in that area to cause rust. I see you're up north so it's expected.
Seal the inside and it will last longer.
Old Sep 3, 2009 | 08:34 AM
scoob8000's Avatar
Gotcha! That would explain it. I wasn't sure if the water was getting in from inside and rotting it from the inside out. I have another car that I get that with.
I'm wondering if it would be worthwhile to make a drain hole or two in the plastic rocker panel cover.
Old Sep 3, 2009 | 12:13 PM
teal_dx's Avatar
Nah, the plastic piece is just the outside cover. It's actually inside the subframe where the water/condensation sits.
Old Sep 4, 2009 | 03:56 AM
scoob8000's Avatar
Mostly then I would probably blame the P.O. for not washing the salt off good in the winter.
I have two identical cars (94 Oxford Blue DX's). One with 225k and one with 120k on the clock. The higher mile one is perfect, the 120k mile one is the one with the rot. Go figure.
my89civicdx
Paint and Body
Jan 10, 2014 04:35 PM
EK FLY
Honda Civic (2006 - 2015)
Jun 7, 2009 03:24 PM
dpkelly
Apr 11, 2006 09:22 AM
nk2k2
Dec 26, 2005 07:37 PM
JDM_ITR
Nov 13, 2002 01:01 PM
