Buying GSR block w/ CTR pistons, need advice on what else need
Like the title says, I am getting a GSR block that has all new oem parts and that has also been fitted with CTR pistons. I need to know if I can bolt this directly onto my si head? If not what I would need? And if it does bolt right on, will the car run right for a couple of weeks till I can get it tuned?
My modification list as of right now is:
DC header, which I'm looking to get a hytech down the road
Magnaflow catback exhaust
Chipped p28
Blox intake manifold
AEM short intake
Walboro fuel pump
GSR cams
And I am in the process of getting rid of my 750cc injectors for like 310cc or a little bigger
I eventually want to run skunk2 pro 2 cams but for the time being I'm looking to get a set of CTR cams
Any input or suggestions would be great. Thanks
Chipped p28
AEM short intake
Walboro fuel pump
GSR cams
Yes, the head can be "bolted-on" with no issues. Your compression will be high. Small primaries (GSR/CTR) and high static compression are not a very good combination.
Also, it will not run very well regardless of the injectors without a tune.
Why is that not a good combination if you dont mind me asking? I'm new to all this, i have a general idea about high and low compression and stuff like that but when it comes to modding my car I get real paranoid and ask a lot of questions and like to hear opinions because I want my car to run great with no problems, hopefully!
theres quite a bit of info in this thread.
https://honda-tech.com/forums/all-motor-naturally-aspirated-44/pct-ctr-piston-compression-ratio-717928/
turbob18rex
Dec 29, 2005 01:20 AM
MRCHUNDOESAY
Dec 2, 2005 09:52 PM
