2000 Acura Integra GSR parts
seatbelt grey bolt covers-$5 for all 4
under steering column plastic with fuse box cover (missing coin holder)-$5
oh **** handle (has one broken screw cover which can be replaced throug Acura)-$5
front windshield with tint on top in perfect condition-$75
center console styrofoam-$5
dash vents-$5
armrest cover-$8
grey quarter panel window plastics-$20
quarter panel windows-$50 for both
driver side relay panel w/relays (I believe it's the a/c relay, fan relay, etc.)-$15
dome light-$10
under hood fuse box with fuses and relays-$20
abs modulator pump w/lines-$50
power steering rack and pinion with tie rod ends (has torn boot on driver side from sitting in storage and being moved around for a year but knuckle is fine and still has grease on it)-$40
gas tank/fuel gauge float (if your gauge isn't working this is probably the part you need to fix it)-$15
e-brake with boot and handle-$20
hood hinges-$15
gas door and cable/popper (realease lever sold)-$15
hood release lever-$5
front bumper reinforcement bar w/styrofoam-$25
a/c heater blower motor-$20
evaporator core-$25
front wiper motor-$25
rear wiper motor-$10
auto cruise unit p72 MT-$10
b-series automatic transmission flexplate w/bolts-$20
d-series fuel pressure regulator-$10
gas cap-SOLD
rear seat strikers-SOLD
under dash fuse box with fuses-SOLD
gas door release lever-SOLD
a-pillar plastics-SOLD
map light-SOLD
passenger side power window motor and regulator-SOLD
cup holder-SOLD
window fluid reservoir with harness-SOLD
trunk lock-SOLD
door panel lock driver and passenger side black bezels-SOLD
shiftboot cover-SOLD
coolant reservoir-SOLD
cigarette lighter with ashtray-SOLD
hatch plastic (black)-SOLD
dash cluster harness-SOLD
main relay-SOLD
trunk actuator-SOLD
rear bumper reinforcement bar w/styrofoam-SOLD
cluster bezel plastic-SOLD
kick panel plastics-SOLD
driver side dash bolt cover-SOLD
trunk light-SOLD
trunk key cylinder-SOLD
coin holder-SOLD
power door lock control-SOLD
black quarter panel & rear trunk plastics -SOLD
fuel pump assembly-SOLD
passenger airbag-SOLD
LS door panels-SOLD
rearview mirror-SOLD
under radio tray-SOLD
driver side power window motor and regulator-SOLD
power steering high pressure hose-SOLD
bare steering column-SOLD
srs clock spring reel-SOLD
abs relay-SOLD
pedal set-SOLD
gsr spoiler w/ brake light-SOLD
quarter panel moldings-SOLD
stock shifter and **** (**** is a little scuffed up)-SOLD
hood latch w/cable-SOLD
vapor canister/charcoal canister-SOLD
oem 98-01 amber turn signals-SOLD
2000 GSR gauge cluster-SOLD
rear filler panel-SOLD
complete moonroof assembly-SOLD
steering wheel w/airbag-SOLD
I'll post more pictures when I get a chance
The big stuff is for pickup only! PM me if you're interested in anything.
dash vents-$5
armrest cover-$8
dome light-$10
hood hinges-$15
evaporator core-$25
gas cap-SOLD
map light-SOLD
cup holder-SOLD
trunk lock-SOLD
main relay-SOLD
trunk actuator-SOLD
trunk light-SOLD
coin holder-SOLD
LS door panels-SOLD
abs relay-SOLD
pedal set-SOLD
Im interested in the front subframe with s way bar.
Is the steering wheel black?
