rebuild or swap
i have a 1995 lx with 170,000 miles with engine problem and cracked head. I have two options 1. let the shop rebuild entire engine for 1200 or swap for a jdm f22b 600-750 for longblock. is it even worth rebuilding or would it be better to swap in the jdm. plus with jdm will i have problems passing Georgia emissions.
Just get a engine with low miles delivered to your mechanic from a online jdm shop, change timing components and be done with it. I have seen the f22b2 and 1's online for about 400-600...
yea i saw a few usdm f22b2 but all have high millage. i am leaning towards the jdm f22b but i am concerned about passing emissions.
Even if they were different. Your mechanic could swap the oil pump and distributor if they needed to. Very easy to do with both engines out of the chassis. 20min tops.
All of the JDM F22B SOHC Non VTEC engines that I have seen are the same as the USDM OBD1 F22B2. CKP and TDC sensors are in the distributor.
Can anyone who has bought a 96-97 JDM F22B SOHC confirm?
