Installing ITR springs tomorrow, any tips/hints?
Old Aug 26, 2002 | 08:36 PM
LS Teg's Avatar
Default Installing ITR springs tomorrow, any tips/hints?
For the rears:
Jack up car
Remove wheel
Undo top two bolts on strut
Undo two bottom bolt on strut
Move brake line away
For the fronts:
Jack up car,
Take wheel off,
remove lower fork bolt,
remove upper fork bolt,
remove fork,
remove 2 top bolts, now remove the assembly
i know i need a compressor which i hav along with an airgun. anything else. you know what size socket fits the bolts? thanks
Old Aug 26, 2002 | 08:38 PM
Ferrell's Avatar
Default Re: Installing ITR springs tomorrow, any tips/hints? (LS Teg)
get a spare set of LCA bolts, snapped mine when taking my susp. apart...
Old Aug 27, 2002 | 12:09 AM
EF'n Fast's Avatar
Mostly 14, 17, and 19mm. Make sure you have a second car lined up just in case something goes wrong.
Old Aug 27, 2002 | 12:54 AM
MR. ARIZONA's Avatar
Default Re: Installing ITR springs tomorrow, any tips/hints? (EF'n Fast)
That's gonna take you awhile.
Old Aug 27, 2002 | 05:14 AM
LS Teg's Avatar
Default Re: Installing ITR springs tomorrow, any tips/hints? (Yes it's VTEC)
where do i get a spare set of LCA bolts, a hardware store? what do you mean have a second car lined up just in case
Old Aug 27, 2002 | 05:40 AM
Neo's Avatar
Neo
Air compressor and air tools can be REALLY helpful, but you'll also need a spring compressor (just in case that's not what you were referring to...) is disassemble the struts.
Old Aug 27, 2002 | 06:10 AM
artifex's Avatar
say it
i found it easier to get the rear strut/spring assembly off after dropping the rear LCA, that way you don't have to compress it as much with those shitty spring compressors. just be careful of the ABS sensor line that runs along the LCA.
Old Aug 27, 2002 | 07:19 AM
uNF$@#!'s Avatar
Default Re: Installing ITR springs tomorrow, any tips/hints? (artifex)
you will need a hammer
you will need a craftsman screwdriver with removable bit for a "chisel"
when you get to the rear springs you will find out what i mean
Old Aug 27, 2002 | 08:09 AM
stumpyf4's Avatar
Default Re: Installing ITR springs tomorrow, any tips/hints? (Soup ****)
Start soaking everything in penetrating oil. Buy some bushings along with those bolts. Do a search on "control arms" and stuff to see what you have to do to older teg when the bolts seize.
Marty.
Old Aug 27, 2002 | 04:12 PM
Zulu888's Avatar
Default Re: Installing ITR springs tomorrow, any tips/hints? (stumpyf4)
how hard do you have to torque the bolt holding down the whole strut assembly?
6thgenva
Aug 16, 2010 03:05 AM
Midori Green
11
Jan 25, 2007 07:22 PM
CrazyKoreanCrx
Apr 18, 2004 06:10 PM
Nice_Dc2r
Oct 23, 2003 10:41 AM
98slvrcx
20
Aug 25, 2002 10:16 AM
