1990 Accord LX idles at 0 RPM
Old Sep 2, 2009 | 02:02 PM
cpjp's Avatar
Default 1990 Accord LX idles at 0 RPM
Would anyone know why my tachometer register 0 RPM when I'm idling? It responds to my depressing the pedal but when I let off it goes down to 0.
Old Sep 2, 2009 | 02:11 PM
Brad_and_the_acc's Avatar
Default Re: 1990 Accord LX idles at 0 RPM
Does the vehicle studder? or almost die? Maybe the cluster is off.. But if the Tach shows 0 and your still idling smooth then Id say its a cluster problem.. I dont fully understand your post though..
Old Sep 2, 2009 | 02:15 PM
cpjp's Avatar
No stuttering or almost dying. It appears to be idling smoothly. But, I have found myself having to give it a bit more gas when backing up or beginning to accelerate so it didn't die, if that means anything.
Old Sep 2, 2009 | 02:57 PM
92civlude's Avatar
Back out the air bleed screw on the throttle body a couple of turns. Also the EACV screen could be plugged.
Old Sep 2, 2009 | 03:53 PM
alkoholikwun's Avatar
^^ along with above post, reset your ECU by pulling the fuse from under the dash for a minute.
Old Sep 3, 2009 | 06:03 AM
Do a tune up on the car.. New Air filter, plugs, wires, battery, check alt... Along with above post.. "IACV" cleaning.. maybe a vacume leak.. Its a little too general of a question for a for sure answer.. Good luck man..
DomonicCB7
Sep 28, 2022 09:48 PM
bseriescrxsi
Mar 6, 2017 03:18 PM
Ross Lauger
Oct 19, 2012 04:06 AM
gonzox911
Oct 17, 2008 04:44 AM
