Re: omni 3bar map sensor with crome..what sensor do i select?
Originally Posted by rick_rabies
i did get the paper. but dont i have to select a certian mapsensor when setting everything up?
Like I said above.. there is a place where you can select a custom map sensor and put in the information that is supplied. It is generally found in the boost tools when you add it to the rom.
