LOOK OUT FOR STOLEN EJ1 COUPE/PARTS PLEASE
I'm not sure if this is the right place to put this. But I think it a pretty good place since my car is most likely going to get striped and sold in parts.
Car was stolen last night in Cicero, Ill 60804.
Plate number: Illinois X69 6333
VIN: 1HGEJ112XSL035172
Body: 2 door coupe EJ1
Color: RP21M-5 Horizon Gray metallic/gray interior with Del sol seats with gray stripe. Rear Beige GSR leather bench seats
Engine/Trans: '94 DB8 with VIN's JH4DB8586RS001131
Wheels: Bronze Rota Circuit 8's missing center caps
-My car has some pretty noticeable dents on the hood (deep) no "H" emblem on hood.
-Front bumper cracked right under the left (drivers side) headlight. Black housing e-gay headlights and corners. Driver side mounted front tag (license plate) mount.
-Rigged up PIAA fog lights to factory locations
-Small dings and dents on rear 1/4's and doors. No rust on main body just a small spot starting on drivers side fender.
-Rear bumper is full of scratches and punched in little dots form people bumping onto it while parallel parking. Only painted black "H" emblem on trunk. Rear tag (license plate) lights are yellow.
-Tinted rear side windows only
-Gsr engine (the normal chipping paint valve cover) and trans running A/C and power steering with P72 ecu
-Spec clutch (blue pressure plate)
-Fidanza aluminum fly wheel
-AEM CAi cut to a shorty
-Skunk 2 duel bend short throw
-Goodridge steel braided brake lines
-GSR front and rear disc brakes rear discs are drilled/fronts are solid
-Omni power front camber kit (red)
-Megan racing rear camber kits (purple)
-Omni power rear lower control arms (posished/painted flat black chipping off)
-D2 coilovers (the purple one's)
-DG Industries harness bar (gray)
-2 bronze c8's with 205/60r17 with bfgoodrich low tread almost gone alot of curbage and nicks and one with a big dent
-2 bronze c8's with 205/60r17 with hankook ventus almost new tires alot of curbage and nicks
-Sony CDX-GT610Ui (blue back light)
Message me if you have any info,Thanks for looking.
