Broken Bolt
I broke a bolt on the coolant thing where the coolant hose hooks up to on the head. I was tightening the bolt and i guess i did it too much and it broke. I tried drilling it out with a drill bit but it didn't work. I was wondering if like the grabit or like those bits where it drills in with reversible threads? The bolt only has only a little left on it cuz i used a drill bit a lil big.
support billy mays and grab yourself a grabit...!!!
http://www.asseenontv.com/prod-pages/progrbit_ontv.html
Get a reverse drill bit and run it counterclockwise.... Or stick another bolt against it and tack a small weld and take it out that way. That bolt is too small for a ez out. There are tons of ways to get it out. Or get a small endmill and chuck it in your drill and widdle away at it. You'll prolly have to re tap it. I'm a machinist
if its that piece where you can adjust it to bleed the coolant fluid, you can remove that piece itself off the head and replace it. i broke one from a D series engine and replaced it in 5 min. imo, it is easier to replace it then to try and fix it. probably cheaper too.
tensaiwung
27
Mar 28, 2012 10:02 AM
