Will a Greddy Turbo Kit for a GSR retain the A/C?......or
........what exactly is the important to make sure it clears the A/C and/or its opponents. It is the position of the manifold or turbo?
Just making sure, the person I bought the kit off of, did not have a/c so he doesn't know if the Greddy Kit retained the A/C
He has the basic kit and added a spearco intercooler himself.
Thanks
Thanks
you might want to look into an aftermarket radiator or fans. i think they are at least an inch shorter in depth...only if stock set up doesn't fit.
[Modified by 98lagen, 9:30 PM 8/26/2002]
Yes, it will retain the A/C. You may need to cut the fan shroud a little, that's about it.
[Modified by FBP Si 2000, 9:30 PM 8/26/2002]
yes you can retain the a/c. you might have to hack the stock fans a little.
edit: doh, hit post too slow
[Modified by Trigun, 9:30 PM 8/26/2002]
This GReddy / AC thing has been posted several times....and several times, its the same answer..Yes you can retain your AC system with the GReddy manifold.
sinister357
Sep 12, 2007 06:51 AM
